Hey all,
I recently had a 7.5in vertex lift installed on my 2011 Silverado by a very reputable shop. Truck looks awesome but my mpgs took a major hit. Only fill up with premium. I know trucks aren’t known for stellar gas mileage but going from 15/18 to ~11 mpg is a killer.
Truck specs:
- 5.3L with Diablo afm disabler used to prevent oil consumption (it works).
- 18x8.5 in wheels with 275/65 duratracs (nitrogen inflated). 2in spacers all around.
- K&N air filter.
- new plugs and wires with ~30k miles on them.
- flowmaster super 44 dual exhaust.
I’ve cleaned the throttle body and MAF. Hooked up my obd II and no codes.
Other than removing the lift what can I do?
Thanks in advance!
Edited by DrDaveMD89
Well you changed the aerodynamics of the truck and is going to impact mileage. Also with louder exhaust there is a good chance you are driving differently than normal.  I have yet to see anyone with a loud exhaust drive normal.  My neighbor seems to have to gun it every time so that's dipping into his fuel economy,  bet you do the same??
Edited by elcamino
I know those type of guys- I’m. It that type, with my daughter and other kids playing in the neighborhood I’m very mindful of my speed. I enjoy that low idling grumble.
I don’t need to be the first one off the line and try to avoid hard stop.
Nail the alignment than install a Linear Logic Scan Gauge II to monitor your driving habits and drive like it's a 10 ton dump truck overloaded  in a school zone and a DOT cop watching; and you have no brakes. That should get you about 2 mpg back. then make it a lifestyle. 😉
That's not me being funny. 2 mph is nearly 20% from where you are. You will be shocked if you monitor yourself and on dozen silly little things you do that hurt mileage. Easy to correct things that will not neuter your manliness. If you measure it, you can correct it....right? The truck silly...........measure the truck........:crackup:
Iowa, eh? We're neighbors. It is a pretty truck though.... Not being a huge fan of lifted that is a major compliment...
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
