Hi everyone, first time posting, but long time reader. I usually try to avoid posting when I can, and  just browse the threads and read about related problems and figure it out from there. Even though I've found many threads that are similar to the problem Im having, I still can't narrow it down to my next step. so if anyone can help, it would be greatly appreciated.
Ok so, BAD oil leak problem with my friends 2005 GMC Sierra 1500. It's had this leak for a while, but it's gotten to the point now where it's starting to leave puddles. I power washed the entire area, and I actually got it pretty clean. Today when I looked again to see if I could trace the source, I had a much clearer picture of where the leaks are actually coming from. From what I've read it seems as though it could be the valve cover gasket, the crankshaft sensor, the rear main seal, or even the oil pan gasket. My problem is that to me, it looks like it's coming from almost all these places. I looked inside the bell housing and I don't see it looking completely soaked in oil. It does however, look like the leak is mainly coming from in front of the bell housing behind the engine, in between the two. I'll attach some pictures. These would be from overnight after I power washed it, so the oil hasn't blown anywhere from being driven or anything. Thanks so much to anyone who's got any ideas!
Edited by Brittney Trefry
Forgot to say thank you
Don't forget to check oil pressure sensor up top as well. Not uncommon for the crank sensor to leak as it ages
I had the same leak on my 2002 at 180k miles.  It just started to leak and put drops on the driveway.  I kind of went over boad to try and fix it but after it was all said and done.  All was well.
I started with the valve covers and  intake. Why intake, because it makes it way easier to get to the oil pressure switch.  My big hands don't do well in tight places.  When that didn't fix it, next was the oil pan.  I had seepage along it on both sides.
So that didn't fix it so next was the rear main seal.  Low and behold, once the transmission was pulled back you could see where the leak was at the seal.  Changed it out and all was well, nice and dry all over.
Sorry couldn't help much but that was how I attacked my leak.
probably the rear main seal but check the top rear and make sure its not running down the back of the engine. a dye test with ultraviolet light will confirm it. standard trans? usually caused by bad thrust bearing
Thanks for the response! So I ended up checking both of those. Unfortunately, neither were the culprit. I was hoping one of them would be, since the alternative is a lot more of a  headache
So I added the uv dye, ran the truck for a bit and did another check. Inside the bell housing looked clean surprisingly. It really appears to be coming mostly from the oil pan gasket AND the valve cover gasket. To answer your question, yes, standard trans. I noticed that the line on the side of the trans had a lot of oil on it. Is that the shift linkage ? I don't think he has oil cooler lines. How would I check for a bad thrust bearing. Thank you for the response
Thanks for the response. Totally sounds like a standard process I would go through lol. Actually those were the steps I planned on taking, so thanks for sharing, it helps me figure out what I should do if I get t wrong. I hope to God it ends up not being the rear main seal!
It is fairly common that the rear main seal goes out.  If you already changed out the oil pressure switch/inspected it, the rear main seal is where I would look to next.  It wouldnt hurt to actually change the valve cover gasket as mentioned already by others.
Hope it isn't but it seems to be the weak link.
to check the thrust bearing take a pry bar and see if you can move the crankshaft forward and back tolerance is in the thousands so there really should be no detectable movement. with standard trans the clutch puts pressure on the thrust bearing causing wear. if there is play save yourself agravation and just pull the engine, replace the bearings and reseal/gasket the engine. a LOT easier on an engine stand than under the truck
On 10/25/2021 at 2:05 PM, Black02Silverado said:
I had the same leak on my 2002 at 180k miles.  It just started to leak and put drops on the driveway.  I kind of went over board to try and fix it but after it was all said and done.  All was well.
I heard that as the main bearing wear the crank falls lower and this is what makes the rear main seal go bad. It makes sense but that means the real fix is a crank grond with new bearings and a seal front and back.
Edited by dna9656
wrong question
I replaced the oil sending unit, the valve cover seals, oil pan, and timing chain cover and front crank seals. I still got a leak; that leaves the rear main seal and I THINK there is some sort of plunger/ plug up in the upper left rear corner of the block I'm not sure but if some one can shed some light on this I sure would appreciate it. I'm told the REAL fix for that ream main is a crank grind (to resurface the main crank journals, replace the main bearings and the 2 seals at each end of the crank shaft; reason being as the crank bearing wear the crank rests lower relative to where it resides when the engine is new, this puts more weight on the bottom of the front and rear seals causing them to leak. Now I think you can drop the crank without pulling the engine but reinstalling the crank would be at least a 4 handed job; esp. while on your back as most of us don't have a lift. Even doing it this way you still have to pull the transmission back, pulling an engine with this many sensors is not my idea of a good time. Following this and other forums it seems that a lot of engine sensors/wiring just break if they are disturbed so you could also count on replacing sensors and the wire harnesses that serve the sensors. If you do this I would be checking out www.partsgeek.com.
Edited by dna9656
38 minutes ago, dna9656 said:
I replaced the oil sending unit, the valve cover seals, oil pan, and timing chain cover and front crank seals. I still got a leak; that leaves the rear main seal and I THINK there is some sort of plunger/ plug up in the upper left rear corner of the block I'm not sure but if some one can shed some light on this i sure would appreciate it. I'm told the REAL fix for that ream main is a crank grind (to resurface the main crank journals, replace the main bearings and the 2 seals at each end of the crank shaft. reason as the crank bearing wear the crank rests lower relative to where it resides when the engine is new, this puts more weight on the bottom of the front and rear seals causing them to leak. Now I think you can drop the crank without pulling the engine but reinstalling the crank would be at least a 4 handed job; esp. while on your back as most of us don't have a lift. Even doing it this way you still have to pull the transmission back, pulling an engine with this many sensors is not my idea of a good time. Following this and other forums it seems that a lot of sensors just break if they are disturbed so you could also count on replacing sensors and the wire harnesses that serve the sensors. If you do this I would be checking out www.partsgeek.com.
With all the millions of these engines out there and some over 400k miles on them, I think you are overthinking this.  Change out the rear main seal and all will be good.   I wouldn't do any more than that for the most part.
Same leak as you. I put the front end on jackstands and a massive oil puddle is in my driveway. It is the rear main seal.
Ok so I have the same issue with an 06 Silverado 1500 4wd with 6 inch lift.. I have changed both oil sensors, the valve cover gasket, the rear main seal, the oil pan gasket then the oil pan itself, intake gaskets, oil lines, even the whole motor .yes that's right I swapped engines.. imagine my surprise to go out there the next day to find a puddle of oil. I'm talking I buy a gallon of oil every two days.. this has been going on for over a year.. I have had multiple people try to find it including a mechanic or two.. the knock sensors had been changed also..and plugs/wires. I'm literally at wits end trying to find this.. I have more oil under my truck than in it most times. The most recent answer was the rear main seal so I bought and changed it and what was once a bad leak has become an extreme oil leak.it leaks when it's running, it leaks when it's not running.. and now the motor has a vacuum on the crankcase.. a strong one.. any suggestions?
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
