Cluster will work (1/10 times from start up) for about 15 minutes until all gauges drop and other indicator lights come on.  Truck was working fine with no issues until a few weeks after my local dealer replaced the fuse junction box. (Check engine light was not showing up when I turned the key so would not pass inspection).
Recently had a local shop try and fix it with a used ebay cluster I bought but that cluster didn't work either. After I picked up my truck, the cluster worked fine for 2 weeks no issues then back to acting up like before.
Is there something that is shorting or coming loose that I should check?
Today leaving work, cluster was working until I hit my high beams and without skipping a beat, gauges dropped.
PHOTOS: truck is being driven.
Thank you in advance.
Youre going to have to find someone who actually knows the electronics on this truck, not an internet guess. Its going to require some diagnostics, not just opening the parts cannon on it.
  • Thanks 1
Just like @Snowcamo mentioned, start with your grounds. There is a ground for the negative terminal that bolts to the frame just behind the passenger front wheel well/splash shield. Check to make sure it’s clean and on tight.
Also, what year is your truck? If it’s an older K2, pull the small front cover on top of the dash where your DRL sensor is. On the driver side, you’ll see a ground there. If there is insulation bolted down with the ground, unbolt it, snip the piece of insulation away and bolt the ground back down snug. Let us know if this fixes it.
@Snowcamo@steelerdude15Copy that. A few buddies said the same about the ground. I will try myself to find a bad connection, If I can't find anything I will have someone look at it. Unfortunately not very mechanically inclined. Will definitely post up any news.
Its a 2015 1500 5.3.
@64BAwagon I figured I'd have to go that route. I just wanted to reach out on here and see if anyone else might have had this same issue so maybe I could try and fix myself or atleaat give a mechanic a starting point.
Appreciate the reply guys.
On the early to mid 2000's trucks it was almost always the ground at the frame/body mount right under the drivers feet. I had a friend that went all the way to Colorado to go hunting, got into the mountain snow and then couldnt get his truck into 4wd. I told him to take a socket and tighten that ground strap screw and sure enough it worked. Come to think of it he still owes me a few beers for that heads up.  LOL
  • Haha 2
There is a ground that is right near the driver's side dash speaker.  Its called ground G218.  Check that out and see if its loose or anything has interfered with that ground.
On 1/23/2023 at 9:40 PM, H.w.H. said:
Adding this from another thread on here.  Shows where that ground is.
Edited by newdude
  • 3 weeks later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
