Just got back from Cary, NC. Was visiting a friend, took my Harley up behind the truck in a enclosed trailer. Everything went great except gas mileage. At 80-85 it only got 11.5. And if I ran any slower, I would have gotten run over on I-40 and i-95. LOL
Edited by Coolmaker
Its not illegal here unless it's after midnight, or november. We weren't out to shoot anyway just looking.
Sprayed mud and sand offf truck since the nonstop rain didn't help taking. It in to the shop after I leave work, I'll be sure to update with what I get to drive for three days.
Sent from my truck using TAPATALK
Edited by SarahsGMC
I was looking in another tread about a 90mm throttle body swap.. has anyone tried it?
You can't use the LS throttle bodies on your truck, they're totally different.
Sarah, I was referring to spotlighting to shoot being illegal. I know you can do it in the off season most places. In northern NH photographers to that to get photos of moose.
Took 'er out for a nice long drive today and found a few back country dirt roads. All and all a good day.
I drove out to Hill AFB
Sent from my DROID RAZR using Xparent Red Tapatalk 2
I've never seen a car with headlights bigger than the wheel/tire combo. Bet those lights would be good for "shining" deer.
Edited by SILVERADOSC540
Bet you can't guess what I'm driving
it fits you well :lol:
I would have gotten the extra insurance, that thing would have made a dune pass
Looks too small- maybe the Spark?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
