2014 Silverado & Sierra will be evolutionary, not revolutionary
Zane
If the 6.2 comes with AFM this time, a tune would fix that issue.
I just can't wait.
A tune can turn it off but a tune can't remove the parts that make up the system, which is where the problems with AFM have been, when they've occurred. I've had no issues with my two rides that have had AFM.
Exactly.
I can't wait to see the HD's.
  • Replies 35
Well got to hand it to Chevy the 2014 interior is starting to look like the F150's....
Got to test drive a new 5L F150 last week, making the switch in a couple of months, getting bored and tired of driving an out dated truck...
Now that the new 2014 details are out, makes my choice so much easier to trade "UP" to a Ford...
thanks for all your great input over the years...
You are better off with a new Ram IMO....The new 2013 model is pretty impressive and they still have the best looking trucks on the market, even though it's been around for a while. The HEMI power is great and their MPG's have been improved to class leading for the new year. Also introduced a sweet adjustable air suspension, and a fancy shift knob to shift P,R,N,D instead of the lever.
If I shy away from GM and the new ugly trucks, I will be getting a Ram. (hopefully my 2 GMT-900's will hold up for a while)
what about the death wobble
HUH?.............Never felt it in any newer Ram trucks I have been in or heard ot it, What is it?
That's like saying, what about AFM using oil, what about the slip yoke bang issue, what about the vibration when switching between 4-8 cyl.
You can nit pick all manufacturers. They have all had their share of issues and most of them have fixes. You can expect thing that are mass produced to have issues sometimes.
The ONLY reason I will not get a new GM truck is because I personally do not like the way they look, especially the interior.
I have not experienced the death wobble in the 08 Ram 2500 4x4 gasser we have
But, dude, it's not a GM, it can not be a decent truck, no matter what.
Isn't my personal truck. I'll drive it occasionally when the need arises. It's mainly my uncles for work in the Utah oil fields, and it tows the travel trailer. the only issue it has had was the transfer case grenading
Lets see....
2003 Dodge Ram experiencing death wobble in 2011 (year the video was uploaded). Sounds like its time for a new idler/pitman arm and probably an alignment.
Now i'll never be able to buy a dodge. I don't want to own a vehicle that'll show symptoms of poor maintenance if I dont maintain it properly.
It has happened in the newer Rams as well. Have a friend with a 2010 3500 & thought he was never going to get it fixed. Had less than 20k on the odometer when it started.
That being said, all trucks have some sort of issue(s), it is just a matter of what you can live with.
You have to be kidding............Did you even read my post?
I said IF I were to get a NEW truck, it would most likely be a Ram. That is based off of the pictures I have seen of the 2014 GM models........When I buy a NEW truck, GM or Ram, I am not going to look for a 2003 that has a worn out front end from not being taken care of. Some people just can't admit that there is more than one good reliable truck on the market.
The truck in that video should not even be on the road. If he would have done regular maintenance and replaced components such as pitman idler arm, he most likely would not have that issue. That thing won't even hold an alignment, you can tell from the video how bad the parts are worn.
Who cares? How about the consumers that might buy the truck. If GM does not care, they will find themselves bankrupt due to lack of sales again. No one wants to see GM once again begging the government for money just to keep the doors open.
I highly doubt that the trucks alone would cause them to file bankruptcy again. Trucks not selling wasn't why they filed for it the first time. Now if they sold better it might have helped out, but there's a lot more behind it than that. Doesn't matter to me anyhow because I'm not buying one, but I'm still glad there trying to keep it somewhat simple while still improving.
Trucks and SUV's are GM's cash cows. Regardless of what causes the decline in sales, when they don't sell, GM is at great risk.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
