LIVE POST: 2014 Silverado & Sierra reveal
Zane
So cool, Cant wait to see!
Maybe this new sierra will pull me away from the mega cab cummins ive been debating on.
  • Replies 243
Yeah i can't wait to see the HD's. The silverado is badass, but just like the last model, i love the sierra more.
I'm waiting for the slew of people to start complaining "They didn't change it that much"
Mervz, after the intial unveiling And speech, Are you able to get up to it and walk around and take pics...
Is there a new suburban too? I was planning on a truck in the next ~2 years but due to expanding family, I may have to go the suburban route and would love a new design to drool over :fingersx:
Yes! I get 15min alone with each truck at 12:30
Is it me or does the bed on the silverado look longer than current trucks? Maybe its because I have been away from my truck for so long.
it is. i love it
I'm sitting here with both live reveals open..... obsessed? nah. This is better than christmas for me though
Stand by... About to get going. If I disappear for a while at any point it is because the WiFi flaked out
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
