LIVE POST: 2014 Silverado & Sierra reveal
Zane
The sierra comes with many of the new features standard, while there available on the silverado.
Rear step bumper is cool, Improved tailgate system for opening & closing..
  • Replies 243
my connection blows so i only see bits and pieces. i like the interiors and i really do love both the trucks alot :) GM did good. Love the Z71 emblem placement on the Sierra
Electric power steering for fuel economy and Less drag on engine..Frame is even stronger then 11-12 models,
I wonder about a long box..
From inside the theater the Sierra stood out a bit more. But out in the daylight or open road I really like the Silverado. Sounds like the Sierra is going to definitely be much more separated in price, pending how they put the packages together.
both of them have upgraded stereo,wifi,nav, features..I guess similar to the ford 'sync' / my-touch'
Both trucks look awesome !!! I am glad to hear they are throwing pretty much all the great new features and technology on it ! Now get some hp numbers !!!!! I just might be trading in sooner than i thought !
They metioned something about a better locking rear differential 'without driver assitance'
I really hope an 8' box is available on all cab configerations
When will the HD's be revealed???
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
