Thanks Fast, I’ll pull off the radiator shroud and take a look tomorrow. Just a hassle. Although, all that is still easier than getting the air box out and dealing with replacing a bulb?
I got my fx-r projectors and morimoto 5500k hids in my oem ltz housings and I don't think my cutoff line is right. When I installed them it seemed the bulb could only go in one way. I'll attach a few pics. Any help would be greatly appreciated. Thanks! 12903de6a6d0a6b653e97cc628886f32.jpg0b35a4a15ec31589605bb168942b7f50.jpg
So it looks like the bulb isn't sitting flush in the socket. In this case it distorts the beam pattern and creates shadows much like what it looks like in the pic.
I would also check to make sure that both metal bulb holders are pressed against the bulb. If only one is pressing it can make the bulbs not sit flush.
Hope that helps.
Phil
Sent from my SM-N920V using Tapatalk
Another bulb out issue with my
Morimoto HID kit for my Sierra. Same issue I had last year, took it apart and it magically worked again. Just noticed this tonight ... on the passenger side so hopefully I don’t have to remove the damn air box. Ugh.
This is why I hate worrying about aftermarket stuff for reliability reasons.
**UPDATE**
I swapped the 35w ballasts from side to side and everything worked. Then I swapped them back and everything still works. Weird .....
I still can’t get mine to turn on no matter what..... I contacted TRS and am waiting for another reply. Have had them in my truck for less than a year. 35w 5500k morimoto elite kit.
On ‎11‎/‎26‎/‎2017 at 4:01 PM, Aaron1085 said:
**UPDATE**
Good to hear, maybe just a simple connection issue?
Edited by Shredzy
I don’t know... I pushed the connections together prior to swapping them and the passenger side still didn’t work. Then swapped them and swapped them back. Bingo.
Seems odd. Any suggestions on ensuring tighter connections?
Hey all. I have a 2017 Silverado 1500 LT and looking to get an HID kit for low beam. Does anyone know what bulb size I need? I think stock bulbs are a d5S or h11?? Not too sure which one.  Any issues with a 55w kit on heat issues? Would I need capacitors/error code eliminators/CANbus? With over 190 pages, it’s hard to dig it all up.
Edited by Silverado17
Not sure what you would need but curious for those with the 50w kits if they have noticed any burning of the bowls after a while.
If your truck came stock with HID (2016-2018 Silverado 1500) then you need the D5S. They don’t make a 55w kit for the D5S yet, only 35W. No canbus that’s for LED.
D5S has ballasts integrated into the HID bulb. It’s still relatively new technology so will have to wait for higher wattage.
Hmm, any replacements come in mind?
Not many out there yet is the problem.
Morimotos. I believe someone has pics and is selling them in the marketplace here. Two different kelvin outputs, 5500k and 6500k.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
