So my wife went and broke the right passenger side mirror on the Avy. They are the power extending style and of course they only extend and retract manually! What are my options for replacements? I hate these mirrors anyway but now I got a reason to change em out! I love the 07 and newer style HD mirrors on the GM's! Will these work on my truck? If not, what else would you recommend? I would love to install power folding tow mirrors using the factory power switch for the extending ones but I have not been able to find anything.
03-05 had power extend/retract
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
I don't think the 07+ non classics will fit the classic 03-07's. But you do have a ton of options out there for after market power, heated, with signal. I am not sure there is much for the power extending ones though. The after market ones look great but they tend to vibrate a bit more driving down the road. Good luck.
Kool vue makes both the 03-05 accordion power extend mirror ane also the 06 style like I have
I ordered up some aftermarket mirros that mimic the HD mirrors. Now I just gotta get off my arse and put em on! lol
Got the mirrors installed. I think they look pretty damn good to me, espcially for the price! Haven't used em for towing yet but will next weekend.
  • 8 years later...
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
