They stick out right at 2' right now. They should be real close after I install the flares.
Got my Rough Country 2.5" level kit installed with 20x10 (-19 Offset) monster rims with 295 55 R20 nitto trail grappler tires. :D Rides different but not bad. I did not drive it far enough yet to see how the mileage is effected, but it seemed to still be dropping into V4 mode fine and the instant mileage looked to be only slightly lower. I will have flares added to it by this weekend I hope. I think it is coming along. So far I am completely happy with this :chevy: truck.
I like this, but I don't see how that can not rub something during a turn. Hell, I was going to go 20x9 with a -12 offset with 295s and it was going to rub.
what bluewrapper said. with 72lbs tires 12.5" wide running at 75+ I lost about 5mpg but if you run 65mph and below I can still clock over 20mpg. this was taken this morning
but this was going to Colorado at 75-85mph 4000ft sea level at that point uphill into a headwind.
5ee193e4-54f0-413b-905a-f798a025c2bd_zps
it will be off if you didn't have the ECM updated for your tire size. I lost 2mpg that's it.
Here's mine, 2" RC kit.
any rubbing issues. Looking at same setup with 275/70/18 x 9 0 offset
No rubbing issues at all, I put the tires on before I leveled it and still didn't have any issues.
It had to be trimmed just a little. I did not think they were going to be able to make it work either but I am completely happy with it.
Your truck looks great! How much trimming did you have to do and where? Very curious I am going to order my wheels and tires today and if I can go with a 20x10 I will!
About two 2" right now. It is at my painter's getting the flares put on so it should be close to flush when he is done.
at the front of the front wheel well you should be able to just move the inner wheel felt looking stuff forward without much problems. In the rear you have to trim some at the bottom of the fender where the black plastic cover is. it is hard to explain because I did not do it I just seen it after the fact. If you look at mine now you can not tell it has been trimmed at all. Sorry I know this does not help much but it is all I know. It is little enough that just looking at it you can not tell it has been trimmed.
Ok great! If it is not much trimming then it is worth it to me to do the wider wheels. I love the look of the wider "tough" stance. Thanks!
I went to the dealership a little while ago to see about having my seat movement fixed and saw this on the lot and thought i would post it up.
2" level (skyjacker I believe) on rockstar2 wheels wrapped in nitto 295-55-20 trail grapplers.
I think the parts guy said they were +18 offset
46A7AFBB-79B1-4B88-92C2-6B6EAD7922F4_zps
DA88BACA-FB1E-4B32-8A3E-0677B2892261_zps
Edited by Tim99GT
I don't doubt that, but it's just a lot more of a swing from different driving conditions was my point.
installed my 2.5" level this weekend as well as the 22" CK375 wheels and 285/50R22 (33.2") Terra Grapplers. Next up 1.5" Body Lift...
20140309_164049_RichtoneHDR_zpsda95z5yh.
20140309_163922_RichtoneHDR_zpssc3pelut.
20140309_181408_RichtoneHDR_zpshpzrn76q.
I really like your setup. Where did you get these wheels?
2.25" Ready-Lift Level Kit, Rear Stock Block.
Front 39"... Rear 39"
BEFORE:
AFTER:
Edited by Luster
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
