Ok guys I'm getting confused on offsets.
I'm going to order wheels and I can't decide on 0mm or 12mm offset, will have a 2.5in level with 295/55/20s.
IS 12mm more in or out?
The numerically higher the number, the further in the rim is. So comparing 12mm to 0mm offset, the 12mm will not stick out as much (this holds true only if the width is the same on both rims)
I'm trying to sell my 17" xd hoss rims and cooper atp tires my offset is +12 and i want more offset so I'm going to a 0 offset , but can't do so until i can sell my current setup if anyone is interested
Thanks wheels are about to be ordered!
Factory 20's are +27mm so either will stick out further than stock. To clear the 295's against the control arms you need a minimum +18mm offset. I'd personally go with the +12's unless you want to be wider than your fenders.
"0 offset" means the hub face is exactly in the center of the wheel. The more positive the number the further in the wheels are tucked, less positive or even negative offset sticks the wheels out away from the vehicle.
is there a way to tell the computer that the tire diameter has changed?
GerryLP :cool:
Yes you can use a Hypertech Programmer to recalibrate your speedo, along with several other changes as well.
From the pics I've seen the 0mm gets the tires about .25" outside the fender
Finally able to get a pic!
2" Rancho Quicklifts up front and RS9000XLs on the rear. 285/65-18 Nitto Trail Grapplers with 0 offset. No rub!
  • Like 4
it looks great.... want to get these so bad and also want to take out stock 1.25" block in back and put a 3" block in its place (1.75" lift) so I retain some of the stock rake with a little lifted look.
**update** just order them.....Rancho has there 60th anniversary rebate get a $126 back on a visa gift card when order front and rears....
Where did you get this deal?
Amazon.com. Check gorancho.com for details and its listed under promotions under Rancho Zone tab. $126 if you order both front quicklift loaded and rear 9000xl shocks. Also signed up for amazon credit card and got $30 dollar gift card towards them also.
Edited by chevy2tuff2006
For those of you with 1.5-2" of level, what max diameter tire are you able to clear? I'm thinking 34" would be the max limit with trimming, 33 with little to no trimming, and 32.5 with no trimming.
As for thickness i think with stock offset 11.5 is going to be max.
I found 295/60/20 Trail Graps for 260$ a tire new. Incredible price honestly.
I was looking at a similar tire. Did you find that online or local shop?
Ebay actually, though i don't see them anymore.
2014 Sierra
20x9 Dropstar 645MB +18 offset
295/55R20 Nitto Trail Grappler
2.25 Pro Comp level kit
Absolutely in love with my truck and can't stop looking at it!
2014 Sierra
Looks really nice. any rubbing?
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
