I've been doing some digging and watching some YouTube tutorials and it does seem pretty easy. I'm going to go with the 2" Rough Country spacers. I figured I'd buy the part and whatever I was going to spend on labor, I would just spend on tools haha your replies are very much appreciated my friend!
I too read up on everything I could find. I've always done my own wrenching on my cars and motorcycles....airplane too but only what was legal on the plane. The only problem I had with the leveling kit was getting the ball joints free. I got the passenger side free but not the driver side. I was able to get the spacer in that side without releasing the ball joint. Took a bit of muscle though. I got the alignment done today and it was just a bit off...actually could have gotten away without the alignment but I'm glad I had it done anyway. The height looks really good. Had a 3" rake now only 1". That's all I'm going to do too. I might switch over to Bilsteins at some point but we'll see.
Good luck....let us know how it turns out!
Edited by '17 Sierra
I own a 2016 Silverado, and it comes equipped with lane keep assist and forward collision warning systems. My question is, will adding a leveling kit affect the functionality of the systems? Has anyone had any issues, or have you had no issues at all? Thanks in advance!
Does not affect it at all. I have both systems as well and they utilize the camera on the windshield. I have not noticed any difference.
Sent from my Nexus 6 using Tapatalk
Is there a advantage/disadvantage to using the upper lift kit over the lower? I've seen both but from what I've searched and read a lot of people seem to use the lower rough country kit. I seem to research everything and over think almost everything before I do it.
I have also seen some that use both the upper rings and lower blocks. Just trying to figure out what is best.
Edited by spartantx117
Rough Country makes their spacers out of a composite material which doesn't corrode. Good quality stuff. Not that the others aren't good either. Anytime you go more than 2", you want to split it up between upper and lower because you're limiting suspension travel by that much so if you put it all on one side, you're more likely going to max out in that one direction more often and that's what is hard on the ball joints.
Question: Has anyone noticed that the lower control arms have notches that the lower crossbar of the strut sits against when bolted down...and the level kit lower spacer plates don't have one built in and essentially makes the bolts bear all the force? Is this something to be concerned about and how strong are those bolts? Sorry if a little confusing just doesn't seem to be the best design. Would like to hear opinions if this matters at all.
I have the ReadyLift 2.25 waiting to install once my wheels come in since the Bilstein 6112's arent out yet and noticed this. I'll try to find a pic.
I see what you're talking about. I just installed mine and didn't think anything of it. They act as a stop, probably in case the bolts loosen up. As long as you torque them down good (37 ft lbs), I think you're good. I went to 45 since more is always better right?! I think if it were a problem, we would have heard by now.
Has anyone ever experienced warranty problems after adding leveling kits?
That depends on how you interpret this GM advisory, or rather how GM will interpret a level / lift kit:.
Edited by Rolling Thunder
Yeah they do and the only level kit I see having something similar to incorporate is the Zone kit which is made out of a composite...but the lip is super small. If it was machined out of aluminum and substantial would make me feel better. Not that I will be mashing this thing off-road but still better piece of mind.
My dealer installs mine. So, no.
2" RC, 275/65/20 KO2's.
I'm just curious why you stayed with 275/65's instead of going with something wider? Maybe a 305/55R20? The diameter is only slightly different (33" with the 275/65's vs. 33.2" with the 305/55's.)
I suppose there is more patch contact area from a 305 vs a 275, so you will get a little more drag (ie. less fuel mileage) but I personally just think that the wider tires look so much better on a lifted/leveled truck.
From everything I've read it seems like the 305/55R20 will fit on a truck with at least a 2" level. There is a possibility for a very minor rub at full lock, but if it does it would be minor. Some people have stated they had a 2" level with zero rub on the 305's.
I just picked-up a 2017 GMC Sierra and put a 2.5" Motofab level kit on it, and am planning on putting 305/55R20 K02's on it in the next week or two. I was just curious if there was a fit issue that prevented you from going wider, or if it was just cost and fuel mileage.
Your truck looks great though! I've always like BFG's for all around tires. Not too noisey on the highway and great off-road in the woods.
you are correct about the contact patch being wider, but the height isn't quite right. 305/55 are 33.2 as you said, but the 275/65/20 are just over 34" tall and they don't rub in most situations.
Yep. You're right. I did the calc's with a 60 aspect ratio instead of 65. The 275/65's are actually just over 34" diameter, as you stated.
So, now the question is taller or wider? Do you go with 34" diameter and a 275mm (10.8") wide tire or a 33.2" diameter and a 305mm (12") wide tire? What does everyone think looks the best?
Well, there are other options as well. You could go in between at 285/60 (33.5*11.2) or 295/60 (33.9*11.6)
I do really like the 305s though.
i have 275/70R18 BFG KO2 and i love them though.
So both ways would be great, just depends on the look you want.
I think the 285/60/20 or 295/60/20 would be about perfect
Best of both worlds
    RSTRICK
    RSTRICK
  • Who's Online   3 Members, 1 Anonymous, 593 Guests (See full list)
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
