NEOutdoors, did you ever find out if the 275/65/20 would work with the 2" level?
or does anyone else have thoughts on this? there seem to be a lot of mixed opinions.
I think it will work if your tire is less than 12" wide and 34" tall on stock wheels.
You are right there at that measurement.
275 tires vary in width wide by brand. Check the width of your tire choice and it might fit.
I have a 2.5" lift to fit my tires. I have very little clearance on stock wheels running 285s.
An aftermarket wheel would allow it to fit with no issues except pulling back the inner fender skirts.
Edited by Smoothbassman
Not the best pic but wanted to show what the 2.5 front and 1 rear level looks like with a loaded trailer. Not too much squat
Just put them on yesterday. Seems like they are good to go. I had to zip tie the liners to make them fit but other than that, they fit with he 2" level. I'll be driving it a bit over the weekend so we'll so if there are any rubbing issues but so far I haven't noticed any. It seems that as long as you stick with the stock tire width you can go up to a 34 with the 2" level.
Mind posting pics? Along with listing the tire you chose?
BFG KO2 275/65/20 - no rubbing issue with 2" RC level and zip tied liners.
Edited by NEOutDoors
Thanks man! I didn't think there would be anyway to run a 275/65/20 on a 2" level without trimming or the NorCal mod.
Do you think anything other than factory offset/backspacing would have been a no go? Or is there a little wiggle room?
I'll be buying aftermarket 20's and trying to figure out if I have to stay exactly at factory specs or if I could get away with say something in the +18 range? There just isn't a lot of 20x9 options out there with exact factory offset
Edited by Iceman22
Wanted the "should have come from the factory this way" look. Just got a RC 2" front Level. I went with P rated 265/70-18 Firestone Destination AT's on stock wheels. The tires are the same width as stock and 1.1" taller. Rides and accelerates just like stock. So far mileage seems to be unchanged as well. Just for fun I also had the stock muffler replaced with a Flowmaster 40 which gave me the sound I wanted to go along with the new look.
Rough Country level/lift and working great
Rough Country 3.5. Highest I could go and still reverse it if I want to.
Who has some GOOD pictures of your CV angles and ball joints with a 2 inch Level? The angle thread has a lot on lifts, not so much on level. Thanks
So I was excited about getting my 2.5" Rough Country leveling kit on my 2017 Chevy High Country 4x4. I put it in yesterday, the lower piece on the bottom of strut, removed the strut spring and put in the round preload spacer, and then put in the 2" blocks. No issues installing. Have my factory 20" 275/55/20 tires and ordered Open Country II Extreme 285/55/20 and will leave them on factory rims for now.
SO IT RIDES LIKE A TANK after install!!! Is this normal? Rough Country says you can keep factory shocks. It feels like there is very little give. I see on so many posts that their trucks ride so good, man I'm jealous. I tried to upload photos but it says files are to big.
Do y'all have any ideas why it's riding so rough?
Should I take out the preload spacer?
I'm confused, I guess, by your replies. You stated my comment made no sense. A truck is manufactured to a certain specification, including the overall length of the strut at rest, length of the lower control arm, length of the upper control arm, and height of the spindle/knuckle. Combined with steering rack and tie rods these elements all work to create steering/suspension geometry. By installing the block that lengthens the strut, pushing the lower control arm down, requiring the upper to be pulled down as well (effectively creating the suspension lift), this changes the factory steering/suspension geometry by moving the knuckle "down", and induces positive camber which must now be aligned out. To remove that positive camber in my case required that so much negative camber be induced by tightening the eccentric bolts in the upper control arms to near their maximum amount of movement. The result being, at steering lock on a level surface caused my sidewall to rub the front of my upper control arm. However later I did find that in certain circumstances during suspension action while turning that rubbing would also occur on the back edge of the wheel, probably due to sidewall roll.
I'd be happy to send some photos when I get back to Ohio from Utah on Sunday. But I guess I'm confused by the fact that your confused.
So, here are the photos from the rubbing at lock between my wheel/tire and Upper Control Arm. 2017 GMC Sierra Elevation, 20" stock GMC wheels, stock 275 55 20 Continental ContiTracks.
This is the small polished spot on the driver upper control arm after lift kit installation and realignment; passenger shows the same wear in the same place.
20170923 155449
This very outer lip is polished all the way around the wheel on the inner side of the driver front wheel; passenger is the same.
20170923 155511
As far as having the lift in, I did 2" MotoFab. Same overall height as the RC blocks, just CNC aluminum instead of plastic.
To @ChevyGuy72 - Ride felt very similar to stock. Just a tad stiffer. However, something to consider is that since these trucks have coilovers in the front, you're not going to get much deflection out of them. Those springs are designed to carry the weight of the entire front end of the truck. I noticed while reinstalling that if I applied too much jack pressure to the underside of the lower ball joint (to hold the spindle in place while I reinstalled the upper ball joint nut) it would start lifting the truck off the stands before it began compressing the springs. I have no experience with preload spacers, so I can't speak to if that is contributing to your rough ride.
I'd have loved to keep it lifted. As you can see, I took the blocks out and reverted to stock. I ran the lift for a week, and after encountering the rub even when I was trying actively to avoid it, I gave up and decided it wasn't for me. I loved the look, it gave it a much more aggressive stance. But I'm already in the hole enough with the cost of the alignment, I don't want to risk any severe damage to the wheels, tires or control arms.
I used the RC lower spacers to give a 2" level. I have not experienced any ride quality issues, rubbing, etc. I too have the stamped steel upper and lower arms.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
