I have a spacer on the top of the strut and one under the strut, if you zoom in to the pic you can see the black Rough Country spacer under the strut, 2.5” kit
I see it, You should be good as long as you have space between not touching.
Geez, the stuff I do! Just sent to my tech guy at 4wheelparts and he said looks good just keep an eye on it to make sure it doesn’t start rubbing. Looks good, go to sleep lol
Thanks brother! Greatly appreciated!
Very welcome, be safe
Got me all fired up, moved a bunch of crap out of the way, shuffled cars and pulled it in the garage just to be sure, side shot of the clearance on each side sitting only on the minor slope of the garage, pictures are looking out towards the face of the wheels, not sure why they uploaded sideways
You’re good, go get some rest, God Bless
fyi the front axle still spin even if your not in 4x4... so if the cv touch even driving in 2x4 will be bad
Hope everyone got that!
On 6/19/2018 at 10:19 AM, mrskiff said:
Sent from my SM-G950W using Tapatalk
beautiful color.  Double cab FTW!!
Put a 3/4" spacer in front to raise it a little. I'm not sure what amount that in turn raises the front. Tires are Nitto Radial Grappler 33x1250x22
To correct the madneride I had the shop 'relearn' the sensors to the calibration was correct, but I think I might add a washer to each sensor for some extra cushion.
y4m7xd1n7bVP2vZobzbqCwhcre6EYpSYpSX7p6S7
y4m7iycp9CgucRguvDb6YIZAZdOSbWGd2PJghViv
The measurements currently from ground to start of fender:
Front =  38"
y4mTANBS2A7_OkAX0V18TjPlBzyZU21SURHqTQ7X
Rear = 40"
y4mlRUZMLTbnzha2DVt2gyexhljSZ69OqqAo_YAf
They do rub a hair on full lock, but is kind of expected.
On 6/18/2018 at 8:21 PM, Aaron1085 said:
Clockwise or counter?
I believe it was counter clockwise, but best to line it up on the wall before and after.
Front =  38"
Rear = 40"
Thats 1.5" lift.  2:1 ratio
Ah!
Well that's good to know. I was wondering that ratio was actually, so appreciate it! Much better to say to people than; "I'm not sure actually, there's just a small space in there to lift it a little."
22 hours ago, EDL said:
Are you guys that are adding the 2" to 2.5" leveling kits also adding a diff drop?
I didn't with a 2" and I've never heard of anyone that has either.
