14 hours ago, acinquegrana said:
Pinion angles don't "seat themselves".
You beat me to it, I was going to say the same thing.  How does a pinion angle seat itself?  :shakehead:
Well I finally got to a point in my schedule to take a picture of the rear blocks but I can’t get it to upload. No matter, they were used two inch blocks that were not tapered at all. I took them out and reinstalled the stock blocks for now. I have ordered the two inch blocks from RC and will install them as soon as I can. The vibration seems to be gone I believe. I haven’t really driven the truck much since I just did the swap today. I will post again later in the week to update. Thanks for all the helpful comments.
On 1/24/2019 at 11:16 AM, SSMUFF said:
Nice truck (twin).  You say you did the 2" up front only but in your signature you mention the 2.5.  Did you do the full RC 2.5 kit or did you do just the less expensive option and lift the front only?
just the front only
Reporting back that after shocks settled I have a slight rub with 295/70r17 Toyo rt’s and method 17x8.5 with a 0 offset. Shocks were set for 2.5” of lift. The rub is very minor and only at full lock in either direction. The rub is only on the felt liner and could easily be fixed with zip ties.
No. Coil overs are adjustable in place. The quicklift is just an extended strut. And IMO they ride like shit.
Ahh ok I gotcha but is it a better ride than spacers?
There’s nothing better riding than coilovers
Sent from above
I found the quicklifts to be about the same as the spacers when I did the swap in my 2012. On my 2014 I went to bilstein and found the ride to be better. On the 2014 I did the bilstein 5100's set at 1.85" with a 1/4" spacer, and I found the ride to be pretty much the same as stock.
Sent from above
Not doubting that but the CST coilovers cost 1200$ thats a little much
I know you’re not. You get what you pay for. You can get a set of Fox 2.0 setting to 2” max, approximately $900. Pop out your whole stock setup, put them in storage and enjoy your new Fox Coilovers. Bilstein adjustable front struts are the cheapest route but not as smooth as coilovers.
If you’re in a hurry and don’t want to save up then the Bilsteins is your comfortable cheapest route or save a few extra hundred and have the coilovers.
Sent from above
For those that are tracking my vibration situation. The vibration didn’t go away after removing the rear blocks and restoring the rear to stock. I plan on removing the 2.5 inch kit from the front now to see if it returns to normal. If that doesn’t work then I will take it to the dealership that I bought the truck and hope whatever is wrong will be covered by warranty. My truck doesn’t even have 5 thousand miles yet. I am now sorry that I ever messed with it. Just wanted it to set level and be able to fit a little larger tire.
did you get a front end alignment when  you lifted it?
On 1/31/2019 at 10:57 PM, Slick66 said:
Yes I had the same shop that did the install do the alignment.
When the shop did your leveling kit, did you have a 1" diff drop added as well? If not, the CV's are probably causing the vib. Simple install, takes about an 1.5hr my yourself and that well get you back close to factory angles while still maintaining the leveling kit. The diff drop spacer kits run about $40.  Just my 2 cents.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
