On 5/17/2020 at 3:12 PM, Bensjamming said:
Any rubbing issues at all? I played it safe with 275/55/20 with 20x9 wheels with a 0 offset and don't have much room to spare when turning on level ground. Especially don't want to be in the woods somewhere end up tearing the wheel wells apart once the suspension has some articulation to it but think I could have gotten away with a little bit bigger tire with a RC 2 inch leveling kit installed
Which side wall do you have showing? Looks nice!
On 3/3/2020 at 12:08 PM, 07 Racing said:
I’ve been reading and reading before deciding what to go with on my truck.. finally got it finished.. motofab 2 inch level, 20x9 Fuel Mavericks +1 offset, 295/60/20  (34x11.75x20) Nitto Ridges.  Minor trimming, Just barely rubs at full lock on the carpet.. nothing else.. love the look and the stance!
Love the setup. This is the exact look that I'm going for on my '17 Silverado LTZ Z71. I want to get those exact same wheels but with with KO2s that are the same size that you have. Could you include a link to the Motofab 2 inch level you bought? Also I want to add Bilstein 5100s all around would that ruin anything with the setup? Any rubbing on the UCAs too?
Edited by kcerri
Hi All,
I have a 2019 LD. I'm looking to level it out and put bigger tires on it. I've read an excessive amount of information trying to figure out what I really need to get to make this work without issue. From what I gather anything 2017 or newer will cause rubbing by retracting the control arms once the leveling method of choice is used. My question is this, has anyone with a 2017+ successfully leveled their truck ~2" (5100s or what have you) and found a combination of 33" tires and wheels to make this work? I understand that using the stock wheels is not going to work due to the retracting of the control arms by virtue of increasing the distance between the wheel and the pivot point. I see that some have used spacers, but I'd have to believe that if using spacers works then just buying wheels with more offset might also do the trick. Also I really don't care how wide the wheels/tires are so if going with a 31" tire on a 9" wide wheel will work then I'm all for it. Just trying to nail down a successful method that includes a newer truck without having to raise it 4".
Thanks in advance.
14 hours ago, Unhealthy Skepticism said:
Hi All,
Thanks in advance.
first off, welcome to the forum...couple things i would say is first...this thread is in the 2014-2018 body style...not saying there are not participants with the newer body, style, but you might have better luck posting this in the 2019+ sub forum.
secondly, if you have a lifted (or even leveled truck) on a 9" tire...it will look like a motorcycle tire on that thing...here is a comparison of a previous 'stock size vs the closest thing i could maneuver for a 31"x9" tire...i dont even think they sell this size, but this calculator is just a program...
good luck on your search!  i hope you are able to find what you are looking for...
2019 LD is also a K2xx body style it’s the last year they came out with the K2xx, it’s not a 2019 T1
ah, thanks for that clarification.
and if that's the case...i am not sure of all the issues that are mentioned...i have a 2016, RC 2" front level, run 265/85r18 rims, no rubbing, no issues...no trimming or modifications needed...not sure what was changed if it is the k2xx...
  • Haha 1
All good I thought the same thing when a friend bought a 2019 Silverado but seen it looked like the 2016-18, the 2019 Silverado has two different types  “T1” style (new body) and the “LD” (K2xx) not sure why they changed the letter to LD
My 2014 Silverado CrewCab LT with leveling kit on it, dropped off at shop going 9” McGaughy lift this is my last photo like this next one will be of it lifted.... (need buy bigger wheels and tires thought)
before picture
After picture
Edited by Frankielozano214
Does anyone have any experience with the rough country control arms for 16 silverados? Any rubbing issues? Wanting to run 275/70r18 on stock 18” rims
2" TrailFX level on 18" KMC XD Hoss II wrapped in 275/70/18 Goodyear Wrangler UltraTerrains.
Wanting to do a 4.5" lift... any recommendations? IMG_2867.thumb.jpg.ba826a74010d42518a94b85144971cda.jpg
Edited by 16silverado35
Just added Suspension Maxx  1” leveling kit on my 2015 Denali. Still has some rake which is what I was looking for.
Nice! It's difficult to find magneride content on here. What size tires are you going with?
Sent from my Pixel 4 XL using Tapatalk
I'm looking to level my 2018 LT Z71. I have settled on the Ready Lift 2.25" kit with upper control arms. I'm also looking to add either the Fuel Contra or Fuel Rebel in 20x9 with a 01+ offset and Falken Wildpeak AT3W in 275/60/20. Any potential issues I need to be aware of with fitment?
I also have the same truck and went with a 2" leveling kit, some 20x9 wheels with a 0mm offset and 275/55/20 durations and could have went with the 275/60s without a problem. You will be fine and most likely don't even need the upper control arms unless you want to try and correct the balljoint angles.
Go with the UCAs as well, 275/60s will rub the newer stamped steel UCAs, older 2014,2015, and I believe the 2016 with the cast or aluminum work but not the newer stamped ones.
Newbie here.   I’ve read / scanned thru pages 400-498 which definitely got me headed in the right direction!
I have a 2018 1500 Denali 4x4 with magneRide and 6.2L, 285/45/22 tires.
Here are my plans, questions and concerns.
Motofab (made in in USA) 1.5" Front Leveling kit, seems to be a respected company right?  Will I need to have magneRide reset? No need to worry about UCA’s or ball joint angles right?  I tow a small toy hauler so I need to leave some rake in the truck so I can tow at reasonably level.
Either Toyo open country ATIII  or  Falken wild peak AT3W tires – Open to suggestions and experiences with these two tires. Can’t decide if I should go 275/60/20  or  285/60/20, suggestions? Plan to run the Ultra Nemesis Gloss Black with Milled Spoke Windows 20x9 with 1 offset.
Can I expect my ride quality and fuel mileage to be reasonably close to factory with this set up?
I really need some better mirrors for towing my toy hauler, what have you guys done that isn’t $600+
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
