I'm running 305/55/r20 which is the same and no trimming rub a little at full lock turn up or down a driveway that's it and very little
SuperAllTerrain
Cant speak for the stamped control arms on the newer trucks since I've read different things about them. But if you go one page back 227, i just posted pics of my truck. 305/55/20's with no clearance issues whatsoever. At full lock left/right and hold, it barely ( and I mean BARELY) touches the sway bar but no UCA's. The rub is so light I can't even feel it through the steering wheel. Had to force a couple of sharp U-turns then get under the truck to check. And I also heavily contemplated the 295/55's but was very happy i went with the 305's.
Anyone help me out on tire size?
2016 GMC Sierra SLT
Stamped Steel Control Arms
Factory 20x9 Wheels - (23220752)
Installed 2.5" Rough Country Lift this weekend, with rear blocks.
I've read through all posts and nothing is clear, tire rubs on one truck but not the other.
I am looking to run Nitto Trail Grappler's 33x12.5x20 (32.76x12.52) or a Nitto Trail Grappler 295x55x20 (32.91x12.52).
Will either of these fit without rub, if rub, how much trimming.
Thanks for any and all suggestions.
2016 GMC Sierra SLT
I have stamped steel and my tires (305/55) rubbed with stock wheels on s Zone 4.5, OBVIOUSLY a lift is quite a bit different from just leveling. However there are other trucks with the same setup running stock wheels so I'm assuming it has something to do with the shape of the stamped steel UCAs.
so on my 17 if i have stamped control arms its possible i will have rub with a level on stock wheels and tires? dang i wanted to keep this truck simple, just a level and slightly larger tires on stock rims.
Depends on the tire size and brand. Based on all my readings with a 2.5 level we should be able to run safely a 32.8" x 12.3" with no rub on oem wheels. I should be getting finally my 2.5 level this Saturday installed and plan to run later some federal 33x12.5 r20 m/t. On my stock wheels. Worse case scenerio if i get some rubbing i'll throw some 1/4" or 1/2 wheel spacers. But iam pretty confident i should be fine since the tire specs of the federals fall on the above measurements.
Just a heads up on the spacers, you can read 1000+ reviews on how good and reliable they are and i even thought about it at one point if i ever encountered rubbing. But I have 2 buddies who have ran them, one a 1/2 and the other a 1in, both couldn't stand them. Both complained about incredible wheel shake after the install, and one even had his right/front wheel literally fall off his truck while doing 68mph down the interstate.
Aye! No bueno lol
I HAD the RC 2.5 leveling lift kit, factory wheels and tires and yes, my driver side tire did rub on the sway bar. Took it off and shipped it back to them, everything back to factory with no rub. I'm still in search of a better quality lift kit but I will not be purchasing RC stuff again. Those plastic spacer that goes under the struts, they both cracked on both sides. It's plastic! Other then that truck rides perfect but it's stock...
Were they running hub/lug centric like bora or cheap ones?
If a spacer causes vibration it's likely one of two things, either non-hubcentric or there is a small rock or debris in between one of the two mounting pads. If there are thousands of successful stories and you know of two that's a 99.998% success rate
Hello all.
I am somewhat new to customizing a truck as I've had my 2015 Chevy Silverado LTZ Crew Cab for just under 2 years and have only done a couple cosmetic things to it. Finding this forum has not been in the best interest of my wallet! LOL
After doing some extensive reading on this topic, I think I have decided to get the RC 2.5" kit but I haven't to decided if I want to keep the 2" blocks or go to 3" as I'd still like to keep some of the rake of the truck. I have also started looking into tires as mine are close to needing to be changed anyways and right now I have my eyes on the following (in the below order of preference):
  • Cooper Zeon LTZ All-Season Tire - 275/60R20
  • Cooper Zeon LTZ All-Season Tire - 285/50R20
  • Nitto Terra Grappler G2 Tire 285/50R20
  • Cooper DiscovererHT Plus Tire 285/50R20
They will continue to be on my stock 20" in rims as cash flow isn't enough yet to get other rims.
Please let me know if I am on the right track or any concerns you see with what I am proposing. Thanks for everyone's insight and help.
Question for all the leveled trucks with 4x4. Have you guys dropped the differential to alleviate cv angles and avoid some premature wear. Or if not then how many miles have you put on your rig with no diff spacers.
I'm in the middle of installing motofab 2.5" upper strut kit. I have the spacer on but after turning the strut assembly 180° to remount it the angle on the bottom strut is way off from the lower arm. Can I do the other side and just switch strut from driver to passenger side?
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
