I wouldn't be too concerned - I was at 74k or so when I first installed mine. Took me a while to discover the world of catch cans ...
So I been looking on Amazon for a oil catch can and I see ones with filters on top and some with out. Which one is better? Or what's the filter on top for?
I just installed my Elite CC and I am really impressed with the quality. I had a Rx and I prefer the Elite over that as far as build quality. Only downside is if you install in spare battery box area like I did they do not provide enough hose but that's cheap from the store.
We should be supplying 5.5' - 6' of SAE Goodyear Fuel Line hose with each kit. I thought that was enough, if not, please let us know and we'll update our kits.
No worries...On my 6.2L the length of hose I got with my kit was at least a foot short to do both runs. I got some nice fuel hose from a local hardware store with the same ID but it actually had a thicker sidewall so I was not able to use the nice clamps you provide. Like I said I was really impressed with the quality of the can. I unfortunately broke my Rx can relocating it (actually the fittings stripped) and I decided to try another one. Glad I did....
Has anyone else had an issue after sea foaming the intake and valves. It seems to sputter when I first put it in Dave and then it acts normal. No engine light. It's been about 4 days since I sea foamed.
2014 6.2l crew cab
Sent from the future via a wifi time portal.
My 6.2 kit came with plenty for the battery box mounting location, but my brothers 5.3 kit was short by a lot so he also had to buy a second hose to be able to mount in the battery box.
GM engineer talking about the catch can he designed for the 2016 Camaro with LT1 to prevent pre ignition detonation in Hot Rod Mag. For the few still doubting the use of a catch can.
Now since GM "believes" a need for a catch can, I wonder if they will make an accessory now for all DI models? Just like Harley.....they said that synthetic oil was the work of the devil and would void warranty's but when they developed their own brand of synthetic all was then magically ok.
Interesting information. I did some searching for pics of the new Camaro 6.2 and noticed some hoses on top of the engine that are not on the Corvette or pickup 6.2 engines. Curious to know how if this catch can has to be drained or just dumps back into the oil sump.
Another 2016 Camaro 6.2 pic. Routing of hoses that come off valve cover and TB area seem to be a little different. Maybe they changed it for production?
Yeah they could have changed it you always have to wait until you see one. I'm curious if it's gotta drain back system like Spurs making
    • Thrust bearing is a very small window.  But nice try.   Turbo oil filter?  Haven't seen any failures.  Change your oil more frequently.  Use a better oil than the factory oil.
    • There is a p/n called out in the one PI that GM has.  Curt 57003 inline load adapter that is used for LED trailers that are having trouble with these newer trucks.  No cutting, no splicing, etc.  GM did update the lighting module around 2023 to better pick up trailers with LED lighting, but it still can happen.     Here's the link to the Curt site for it - 7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) SKU #57003 by CURT   The PI I am referencing - MC-10208985-9999.pdf   Its not just a GM deal either.  Newer Fords and Rams have this same problem.       In another PI, they recommend that the trailer has a Pollock brand 7 way on it as that is who makes the truck sides for the OEMs.  GM is also big on making sure the trailer is trouble free.  So no wiring issues, all lights are functional, better quality 7 way plug, etc.     The other PI I am referencing - MC-10178359-9999.pdf   The model year range is older but it is the current PI for 2014-2026.  It calls out the Pollock RV HD 7 way they recommend.
    • That's part of the problem...the EGR has already been replaced, and I've already had the complete intake assembly removed, and the EGR passages were clear at that time. That leaves wiring, PCM, or another variable that I wasn't expecting. Best I can tell, it's not wiring or the PCM, so I'm grasping for straws.   The PCM uses the MAP reading to confirm the requisite loss of vacuum in the manifold when the EGR activates. Since that's vacuum related, it involves a lot of other systems which could play a role.   The overall diagnosis has to be considered too. The fuel lines in the intake had rubbed through and were dumping fuel into the intake, drowning the cylinders in fuel, and putting raw fuel into the sump and cat converter. The fuel system has been fixed but the complete path of damage may not be. If the cat was damaged and melted the internals, it could be partially obstructed and also playing into the EGR issue.   I'm retracing my steps; trying to go back to thinking thinking Horses not Zebras based on the clues I've been given. These engines aren't *that* complex.   Could it be, now that the truck is running well, that carbon and crud from being run with the fuel system in disarray is now dislodging and clogged my clean EGR passages where I can't see?  That's what the code is actually saying. The flow is restricted, dummy. Retrace step 1.   I may just need to remove the lower intake again. Before I do that I'm going to try removing the EGR and running the engine for a few seconds to see if it will blow anything lodged in the egr passages out through the open ports.     That's been helpful in the past. For the spider injector, there's no guarantee I'll get a working one. The spider I have seems fine now that the high pressure fuel line isn't making an early delivery via large hole. SO at least I'm not marooned and looking for one of those.   Row52 (dot com) is also a good one for watching for vehicles at local yards.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
