This is a epic fail on gm's part. Multi billion dollar company and they can't fix there seat. Come on gm you look lazy and greedy.
With all the millions of recalls GM is having right now we are last in line, much like the ignition problems they are having someone will have to have a serious accident before it gets addressed..
Thank you to hotrodz37. Just did this fix with a 3/4" hose clamp and some spare rubber laying around the shop. Works great and no more seat movement.
I too have this problem, 5500 miles. I have not spoken to my dealership yet, but will do this soon. Odd that I can trace this forum thread way back to last year and GM has not been able to fix this automatically for their 2014 vehicles built this year.
I have done the hose clamp and rubber fix to my Sierra and it has worked FLAWLESSLY the past week. I am so happy I can drive without tightening my cheeks around turns :)
Do you have any part #'s off the work order? I'm interested to know what exactly they replaced? Much appreciated and please report back in a couple weeks to see if the repair holds.. Thank you from us all...
I'll let you know. They did it last week and it's been fine since. They had to order in the part took 2 or 3 days. They also totally redid the frame and no more rust or chipping. Total removal of the grease/wax then under coated black. They do about a truck every 3 days.
I did the rubber and clamp fix a week and a half ago and it's been great ever since. It's certainly made the driving experience so much more enjoyable!
I really haven't followed this thread since I got rid of my first truck with its moving seats. I'm glad someone found a "fix" for a problem GM can't seem to figure out.. I'll keep this in mind if I have any issues with mine. Thanks hotrodz for the clever fix. BTW I clamped my adaptive valve open w a hose clamp too lol.
I have moved it every way possible and mine is still holding strong. Go for it!
Is your fix still holding up? Looks like I will be heading to the hardware store tomorrow !
There is supposed to be a redesigned part to fix this issue, still waiting on it to arrive but once it does and gets installed I post a picture.
I went ahead and did the hose clamp fix today and it completely eliminated it. Will have to see how it holds up. Hopefully it holds till the new part comes out.
I have only had my truck for two weeks and maybe it was my imagination, but I was hearing a click when I went around a curve. I didn't feel any movement, yet. So I decided to try to do the DIY fix on page 19 of this thread as a preventative measure to support the existing hardware.
The 1" hose clamps were no problem to find, but I wasn't sure where to find the clamps with the rubber insert. Anyway, long story short if you want to do this the clips in the photo below were what I used. I found these in the electrical section (near the electrical conduit) in Lowes. These clamps were 1 inch and I didn't need the total amount of rubber so I clipped off what wasn't needed on the hose clamp. Easy fix, just hope it keeps me from getting the full fledged problem. Ounce of prevention worth a pound of cure?
You can see the product and product #. The Lowes item #48633
Each pack came with one clamp and was $1.68.
Some of you may have already known where to find these, but I had to hunt. I thought I would share the info in case there was someone else like me out there searching for these.
You can see the unused clamps and the excess rubber I trimmed off in the picture below.
00223A15-3823-44EE-9099-D09E06F2E33F_zps
I had a hard time finding those clips too. I ended up cutting a bicycle tube and putting the hose clamp over that. So far so good zero movement.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
