Have never heard of iBoards, reminds me of the factory ones on our Tahoe.
How is the fit and finish?
They do look good!
Edited by JimCost2014
Recently installed some iArmor Steps for my 2016 Silverado WT. Video below:
Edited by fondupot
How wide is the actual step area?
I have a 2017 GMC Sierra slt Texas edition. Didn’t come equipped with the electric running boards but bought the oem factory ones from someone I met. I been looking around for someone who can wire them up for me, my issue is I can’t seem to find anyone to do it. They say I need the harness, which I don’t have . I’ve taken the running boards to gm & they inform me there’s “no way” they can do it unless I buy the “whole kit” from them. I’ve also went to other professionals who “specialize” in that area, but I’m getting the same response from everyone.that since my truck did not come equipped with the electric running boards my truck does not have the bdm module & can’t be done.. but I did find something on YouTube where a guy in a similar situation installed some factory running boards on his truck which did not come equipped with them.. he made his own harness & did his thing ‘ they work perfectly fine.. can anyone give me some good & simple feedback on this issue, it is greatly appreciated. Thanks in advance.
contact pgamboa on here
The dealer route is going to be well over $1000. If you are going to spend that much you might as well spend that much on a nice set of Amp Research.
Since I already have the electric running boards (but no harness) it doesn’t make sense for me to spend even more money on buying another set if I already have the running boards. I feel since it’s just an electrical wiring situation, it makes more sense to just find someone who knows about the topic..
After having the ICI magnum RT steps I’m replacing them and selling for cheap.
Im really not a fan of the 2:drop down step look thought I wanted something different but turns out I hate them.
Step itself is too small
step is made too far forward
i was able to pick up the Westin thrashers for 458,00 waiting for their arrival.
i bought the GM branded step bars for my 18 crew cab (same bars that came on the real tree edition silverado)
i used as much copper antisieze on the bolt threads as i could and smeared 5th wheel grease on all the speed nuts and contact points between frame and board brackets.
I had to pry out 4 black plastic caps in the side of the frame to slip the speed nuts. Do i just leave these out or should i modify them to make them fit again?
On a sid enote i got some of the tube caps thats supposed to seal the tube crossmembers in the rear of the frame - are these a good idea or do these just trap moisture and cause rot?
On 3/13/2019 at 6:50 AM, shadrickjm said:
I have the GoRhino RB20's.  They fit nice and tight up against the body ot the truck.12-21-18.thumb.jpg.ae4cf7f8e7d67371281976ac93406dc1.jpg5c890a990d797_Sideshot.thumb.jpg.37bea09914ef4cdb95a47bd7b69c3f2f.jpg
Those look really good! What tire/wheel size combo are you running?
Thanks.  Wheels are Fuel Trophy D552 18x9, and the tires are Nitto Trail Grapplers 285/65/18
On 6/18/2019 at 12:20 PM, Brian2015 said:
Replaces 2 yr old rusting NFAB bars with iBoards, took about 20 minutes to install. First thing I noticed was how much easier it is getting in and out,  not only for me but the wife and kids. When I removed the NFAB bars, the tubes were full of rust crumbs.
First snow/ice and they broke from the refreeze.  Garbage.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 463 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
