Looks like the 2016 Denali 6.2 gets the UQA code for the Bose radio system and the NKC code for the noise cancellation which is only available with the L86 6.2 engine. Cannot tell that it does anything or not. I wonder if it can be turned on and off to test it or not?
Have found majority of codes for my 16 silverado. Cannot find many though. I know dealer can run them for me, but I have enjoyed hunting them myself when time permits. Ones I need help with are XYI,VRK,H2R,MAH,VMN,260,152,1WT,4D7,AVV,AYK,GBA,I16,N2Q,VHM,V8D,WMG,an YM8.
XYI - ?
VRK - Value Added ASM Roof Trim
H2R - Interior Trim Config Level 1 Jet Black/Dark Ash
MAH - Marketing Area North America
VMN - Panel Center Magic Black Paint & Bright Silver Metallic Paint
260 - ?
152 - ?
1WT - Package WT Option 1
4D7 - Interior Trim Jet Black/Dark Ash
AVV - Identification Effective Point Control 2016 1/2 MY
AYK - Restraint Head Rest 2 Way Adjust
GBA - Primary Color Exterior, Black
I16 - I'm pretty sure this signifies the 2016 model year.
N2Q - ?
VHM - Prognostic System Vehicle Health Management
V8D - Vehicle Statement US
WMG - VIN Model Year 2016
YM8 - Identification Limited Personalization Option/LPO
I have a 2016 Chevy Silverado I recently bought the tail lights that Gon on the 2016 Silverado ltz they're led but every time I turn my turn signal on a message displays saying my signal light is no working I read that I need a slt code to program the light where do I get the code from and how do I program them?thnx in advance
NKC was also included with non-denali 6.2's prior to 2016.
My 2015 SLT had it. Never did learn of any way to turn off to test.
This is from the 2015 1500 sierra order guide:
NKC Noise control system, active noise cancellation
1 - Included and only available with (L86) 6.2L EcoTec3 V8 engine.
(The '1' indicated it was only available on SLT, 1500 Denali's were in a different guide section)
It also came with the 6.2 on 2015 1500 silverado (which meant only on LTZ's and High Country
That link don't work now :(
Sent from my XT1585 using Tapatalk
I just clicked on it and it worked for me...it is basically the GM Customer Service profile and to the right there is a box that says "Send me a message" which opens a window to PM the GM Customer Service person. You have to be logged in to send a message to them.
http://www.gm-trucks...stomer-service/
Another way to get to them is by going to the top of the page and click on Members and then search GM Customer and you should see the profile for GM Customer Service. You can click on it and send them a message.
Anyone help with these codes? I've found all the others from my 16 LT. Know the 2LT is the package lvl, but wanting the official name.
AXK
H0U
I16
NUF
UMN
VRK
WEA
2LT
4AA
6F1
Edited by bndawgs
AXK
H0U
I16
NUF
UMN
VRK
WEA
2LT
4AA
6F1
Best way to find RPO codes is to go to the Chevy website and scroll down to where it says help center and chat now. Click on that and wait for a service representative. Then ask the for a build sheet for your vehicle. Tell them you want the whole build sheet and they will ask for the last eight digits of your VIN and mileage. After that they should be able to email it to you. It took me around ten minutes to get done.
I just did this. Thanks for the info.
  • 3 months later...
I contacted GM about build sheet for a new to me 2014 - they now want $50 to obtain it :(. Anyone have a 'cheat sheet' for these almost 4 year old trucks?
I tried contacting the GM Service guy here on the forum but every time I tried to send a PM to that account, the forum kept telling me I couldn't.
After seeing the above message, I went to Chevy's website and the chat rep was happy to send me my build sheet. Thanks!
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
