ok so the led light behind the grill will be more intensive than i first thought.. . you have to remove the whole front basically.. . which i didn't have enough time this weekend to start...
anyone have any tips .. ?.. .. it looks intimidating....
Couple videos you can review before you start. I'm planning on doing mine Friday (been putting it off for a while). If you were closer to Houston, I'd say stop by and we both trucks.
double-post - delete
Edited by bgweed
word.. thanks yeah i did see the 2014 light bar install.. it was a good vid.... again, i can do it.. just more than i thought it was going to in tale.. i just need to take a day and start-finish it.. ... but its been so hot... i might wait till oct .
good luck with your install!...
Looks tougher than it really is. Took me 2 hours to install my lightbar with a wireless remote. Wasted the most time worrying whether I was going to break a clip....
its not that difficult. Other than getting the top bumper fascia off( upper plastic piece of bumper). If you got the rough country kit it's as simple as install a couple bolts on existing holes on the radiator core support. Good luck with the install!!
2015 1500 LT Silverado Midnight Edition
Edited by chrispassas21
thanks guys!!.. .. yeah i bought some longer bolts.. so i can attach it to the radiator supports... i'll drill holes through them... as for the switch.. i'm going to try and locate it in the cig lighter.... . i'll update this when i attempt and get it done.
Edited by Crstfr
you could do a wireless remote if that's what your looking for also!
Found an hour of free time yesterday and installed GM - Illuminated Door Sills. Love the way they look! Of course, made a how to video. The box didn't come with instructions and tried searching he web for some. Came up dry. So enjoy this How-To.
Part # 22933513.
Before:
After:
https://youtu.be/6vFuV9TAGZE
Edited by pgamboa
  • Like 21
Just got my BDS 6"lift installed new falcon wild peak MTs 35/12.5
Fuel Savage 20
Amp research steps
D badged
The BDS lift drives amazing feels exactly like leveled with 33's Falcon at
The MTs are at a little bit louder but definitely quiet for MT
No rubbing at all
Will post some pics on level ground tomorrow
Edited by Crazyfly
  • Like 9
Took her on a 3k mile road trip to Montana last week.
  • Like 5
Has been a busy few days but here is what I've done in that time. Removed air dam, replaced antenna with a stubby one, added Readylift 2.25" leveling kit, 20x10 Moto Metal 970s, and 305/55 Toyo AT.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Rolled over 50k the other day on the way to work. Today I installed some LED switchbacks in the front signals now no more orange unless i'm turning.
I thought about doing my dash pieces white (to match my truck) but was afraid it might look to ricer for me.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
