3 hours ago, pgamboa said:
You get that from me? I don’t have forum names linked to customer names if so :)
yes I ordered the power fold turn signal mirrors, switch and harness a few days ago
Waiting on switches to come in from GM. Hoping next week.
23 hours ago, pgamboa said:
Been a while since posting on this thread. But really existed about this one!
Finally had a moment to review the AutoSync!
Loving this thing! Enjoy!
So to use this to disable AFM, does this have to stay plugged in all the time?
Yes
Just washed my 2014 Silverado 1500 LT probably for the last time before she gets her new face lift (2016-18 LTZ Frontend but with the painted bumper less chrome is ??) Next Sunday!!! 04D578E3-5617-4D24-B30C-BB4A350E129E.thumb.jpeg.163e7e033891f704867d2940065a189f.jpeg
HARNESS SHOULD BE HERE SOON
  • Like 4
traded my '16 silverado in for an '18 Sierra.  loving the GMC and the 6.2L so far.
  • Like 4
changed the 3rd brake out with a full red led lamp, modified it for no cargo lamp function I never use it anyway, I discovered why these china lamp housings leak, the screw mount hole protrudes out farther than the weather seal, so I used a dremel and trimmed it down to the same height as the oem one and now it fits perfectly. I did end up cracking the housing tightening the screws down so I have another one on the way but it works good once I corrected the wire harness it was completely backwards from where it should be out of the box, typical for china junk.
Just replaced my original G2 Diff Cover that I stripped the fill bolt with a whole new G2 Diff Cover
Out with the old and stripped
In with the new Diff Cover
Refilled with Amsoil 75W90 [emoji6]
Sent from Above
You should have messaged @pgamboa about getting an adapter harness.
It’s going to be 76 in Colorado today with a couple inches of snow tomorrow. What else would I do?! I gave Katie a bath and a quick spray and wipe of Hybrid wax.
Nice truck!  The Ford behind you looks great too!
He’s working on a harness for the 2014-15 to the 2016-18 LTZ Conversion so for the time being I wanted to install my frontend but I will be swapping out with his harness as soon as it’s available because this one doesn’t function like factory. Already told him let me know when it’s available I’ll definitely be swapping this harness
Edited by Frankielozano214
    • Looks tight. Not a lot of working room. Hows yous knuckles?
    • Spot on. The government makes ridiculous mandates, and this causes manufacturers to jump through hoops for every TENTH of a MPG. Main reason quality is in the toilet and prices are in the stratosphere.   The gov't tightened the MPG requirements so much 5 years ago that the only way manufacturers could meet these absolutely ridiculous numbers was to go all EV. Hence the push.     Nobody hates good MPG, Atlas - nobody is "whining". Your side has that trait all locked up. What a stupid argument attempt!   What I particularly hate is the government meddling in the free market system. Had this system been allowed to work as designed and intended by our Founders, cars and trucks would be hitting numbers that would blow our minds, all while costing 30% LESS. Not only that, but engines could probably hit 150k miles again without needing major internal surgery.   My forty year old Ford 302 has 312k on it. Wonder what changed?🤔
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
