On 8/18/2020 at 3:31 PM, kwOH said:
Got a killer deal on some brand new OEM wheelhouse liners with hardware.
Are these fronts or rears? Could you post part numbers if it is fronts. My fronts have some damage and I would like to replace them.
Edited by Eddie 70
Rear, sorry.
1 minute ago, kwOH said:
Rear, sorry.
No biggie.
I see GM sells the rears in pairs but the fronts are sold singularly as far as I can tell.
No biggie.
I just happened to come across these, they were kinda like new old stock.
Did my Frankielozano214 impersonation [emoji1][emoji2957][emoji1][emoji40]1adc011faf959d638e3286616e8fc00f.jpg
Sent from my Pixel 3 using Tapatalk
  • Like 4
Can one of y'all help me out here. I got this catch can from a member and I'm trying to find the damn clamps for this. Can I just use regular clamps for the ends? I can't find the hose quick clamps anywhere. Also, those who are mounting it off the radiator, what size of bolt are you using? 11mm?
I used a regular clamp. No problem.
18 hours ago, Frankielozano214 said:
Installed this driver side assist handle matches perfectly!!!! 062F8562-B144-42D7-BBDB-6F500F9451EB.thumb.jpeg.642931bb41b69ceef18e7b4ded28e8b7.jpeg
is there a part number for that?
You can probably find it cheaper, id look around seen different brands on amazon but this one looked to be a GM part so if it were me I’d buy this one.
GM Accessories 23285090 Driver Side Assist Handle Package in Gray https://www.amazon.com/dp/B07B3C6P2Z/ref=cm_sw_r_cp_api_i_EzRqFbYCSWEPY
Put my AirRaid Jr kit and filter in today
I’m actually pretty amazed at the sound/throttle response difference it makes. I was not expecting much at all.
Did some trim vinyl wrap when I was redoing my door handles with LED turn signals. Only one I had issues with is the driver side vent trim . So for now, those 2 trims are staying silver [emoji28]. I'll come back to them when I have enough time. I still need to do the steering wheel.
Oh, I never got to installing the Chevrolet bowtie I had ordered waaay back, was supposed to get painted.. didn't pan out. I bought paint, but wanted to try wrapping it first. Did the back.. took awhile and steady handles/patience. [emoji16]. This is the back, need to make time for the front.
I also installed a PAC AmpPro AP4-GM61. Replaced the center console Bose sub with the box from eBay and installed a Kicker in there.
Not all today, just here and there the past 2 weeks as I had time.
Sent from my SM-N986U1 using Tapatalk
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • // Thank you, also for your  response. More information is always good. This 2013 GMC is most likely my 'forever truck"-I'm 77 and retired...and truck only has 42K on it-very clean-so I try to keep it that way.  Tks again for your  response- glenn
    • I started my install this weekend. Everything was pretty straight forward but I ran into one issue with running power through the firewall. The nipple grommet on my High Country already has a small harness running through it - has anyone else ran into this issue? And on the engine bay side, does the wire basically just penetrate the factory wiring boot? I did this on my '22 Trail Boss and it seems much easier but thats been a few years. My other thought would be possibly drilling a new hole adding a rubber grommet just to the lower left of the factory hole. Thoughts?   Has anyone used a T-harness off the Bose amp and obtained power from there? It seems a little odd that such a small amp needs 3 power leads
    • ///// Ok--Thanks for that info--I could not find yesterday when I looked for the specs on that NAPA filter what I wanted. Their website is not very user friendly. I buy all teh filters for  our three vehicles once or twice a year. Have always run NAPA Gold on everything I own....I buy it thru my Son's account for his business-which he has a Heavy Equipment repair shop-one reason he uses NAPA so much-they have such a full line of coverage for just about anything/anywhere- He gets s  good discount because of volume bought. Anyway-Thank you -Sir for your response.   glenn
