I ordered one and plan to stick the old one in the tool box. For $30, it’s pretty damn convenient until it’s not and you can easily throw the old one back on.
Yeah i would def save the stock one. I guess my concerns are more about being out somewhere like on an ATV trip and all the oil leaks out while you’re out riding for hrs cuz the valve failed or something and you’re a few miles away from anything. And god forbid you don’t notice and start the truck. Idk. Maybe I’m overthinking it. Hahhaa. But I do that with stuff like this.
Just curious how durable they are.
Improbably, both of my windshield wipers failed yesterday at the same time in the exact same way - and it hasn't even been below freezing for more than a week. Oh well, these were on the truck when I got it about a year ago so I had no idea how good they were anyway. Upgraded to Bosch Icon based on the recommendation from The Wirecutter; they've never steered me wrong in the past. I used to do the Rain-X Latitudes, so it'll be interesting to see how these compare.
I have always been a die hard Bosch fan for wipers. Maybe it's just my bad luck, but never had good results with longevity of Rain X. I think the Bosch Envision series were introduced 2 or so years ago, and they are by far the best set I've ever owned. Going on a year and a few months on the same set that have seen lots of rain, snow, and everything in between. Still function like they did on day 1, and no streaking!
Put on new wheels today, went from silver to black.
35x12.5x18 BFGs. 18"x8.8" Chevy stock black aluminum.
IMG_0145.thumb.jpg.c40aaad0f6a6e560ad2eae6a08cb1a23.jpgIMG_0143.thumb.jpg.c34daa7d279275bd957de508c299787c.jpgIMG_0144.thumb.jpg.6a2ff59f4a08a4261a9f5d63e5ffd755.jpg
Get you a rubber vacuum cap or something similar to cover the end of the Fumoto valve and nothing will drain out if the valve gets hit. You can also tighten it to where the handle is up out of the way so nothing can hit it.
I've got a section of tygon tubing I slip over the end of the valve and drop into my drain pan when I pull into the garage when it's time to change oil. Open the valve and walk in the house. Come back out the next morning and I know I have drained the oil while it was hot, no splashes, no mess and easy as can be.
Edited by Eddie 70
Ok so these fumoto valves; I was toying with the idea of putting one on my ATV a couple yrs ago and I didn’t because someone mentioned the valve got all jacked up from trail riding. And wouldn’t open and then wouldn’t close, And I started thinking would I also NOT want one on my truck etc for the same reason? And thinking about salt and ice/snow in the northeast? Will these things hold up to that and not leak for years??? Looking for real opinions cuz I know alotta you guys have em and I don’t think I’ve ever polled a forum about it, and I have no personal experience.
I’ve ran Stahlbus drain valve on my track bikes. Works great!!!! It’s a lot smaller than Fumoto valve and looks a lot cleaner. A lil expensive but definitely worth it.
Oh now THAT looks cool. Metal cap to protect the valve. And I take it when you push the other part with the hose into it that’s what opens the valve?
Thanks! I’m gonna look into these. I like that nothing is exposed when the cap is on. And that it’s metal.
Yup, push it and turn and that’ll start draining it. Very simple and the cap also serve as a second seal.
Wanna share what and how?
There off the T1's you gotta do a little trimming but took a minute with a Dremel.
Sent from my SM-G986U using Tapatalk
Ground off the parting line and smoothed my lower control arms on the front side. I’ve been thinking about doing this since I removed the lower bumper plastic.
  • Like 4
Had a nice 60 degree day this weekend to detail inside and out. Not often we get above 30 in March! Bucket wash, clayed, Turtle Wax jet black spray wax and CG VRP on all plastic trim & tires. Wanted to see how the spray wax works compared to my normal sealant routine (chemical guys black light followed by butter wax). Just in time before we get snow and rain tonight.. 😕IMG_3949-R.thumb.JPG.0c92e904d2c0930df0ccdf091c0cff78.JPG
IMG_3951-R.thumb.JPG.132eb539d91ae79f68e02d86ee596fa6.JPGIMG_3968-R.thumb.JPG.21deb1de86637dd08de7b0d4bae2acd7.JPG
  • Like 9
I WISH!!!
We may have been lucky to break 50ºF today in the high desert in SoCal.
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
