Got around to pulling all the parts out to make sure I have everything. The engine should be out tomorrow and hopefully new parts will start going in.
quick parts list
-L86 manifold with additional port injections. (will be installed with 50lbs injectors but won’t be hooked up just yet)
- 2000cc meth injection
- Borg S476 with billet wheel
- Cam Motion turbo cam
- BTR .660 dual valve spring
- Johnson 2110R lifters
- CHE trunnions
- Turbo Smart WG / BOV
- ARP head and main studs
- L86 OEM crank
- GPI “drop in” pistons and rods
- OEM head gaskets
- custom Garrett core intercooler
- Derale trans cooler (will be under the bed). Removing the 40k Trucool from up front.
And a bunch of other little stuff.
Edited by CajunFries
  • Like 4
1500 PAGES?!!!!!  HOLY CRAP!!!!
Drove my truck for the first time in 10 days, $8/gal sucks, been driving my son's car or my wife's CR-V Hybrid, and driving my truck once every week or two.  As I was driving down the main drag in town, I heard something flopping in the breeze under my (open) sunroof.  I usually drive for about 10 minutes or miles with the sunroof in vent and shade almost closed, to draw the heat out.
Found it to be a VERY simple fix.  Just re-engage the clip/slot from the front to the back.
Edited by Ravenkeeper
$8/gal?!?!? Where are you at?!???
I removed the plastic fender pieces and pulled the wheel well insert. Gave everything a good cleaning, then re-installed.
Super easy to do, don't need to remove the wheel. Just a T15 bit and a phillips screwdriver.
finally received the builtright bedside rack, I'm 2 days into a rather mean cold that has me wore out, I will try and piece it together in the next couple days
Ok, I exaggerated a little bit.  Average price around Antelope Valley (Lancaster/Palmdale) is $6.75
Ahhh gotcha. I havnt been out there in a while. Used to ride at willow spring all the time.
10ft of heat sleeve for the AC lines and couple of wires and Heat shield for the battery trying to protect it from the heat from the turbo. 35D83E49-FC03-403F-81B9-2F4ED8B52782.thumb.jpeg.9b3e265033247dd0d6266fe5eac62bb3.jpeg
I am definately going to do this for my 18.
Finally got a chance to test out my new electric pressure washer and foam cannon. Was too into the wash I forgot to take a picture of it all foamed up. Clayed/waxed after the hard winter neglect, full interior detail as well. Much needed!
Next week going to drop the trans pan and change filter/oil. 48k since the last time it's been changed and shifts are starting to firm up more than I'd like. Hoping to get as much life out of this 6 speed before I start getting the itch for a new AT4...
  • Like 5
What have I done for my K2 today. Well great question. I ended up finding a torn CV boot. Now researching my options.
  • Sad 1
Insulated the doors with ccf and ccf/al. Sounds better for sure. Now to chase down a door panel rattle.
Edited by Snowcamo
  • Like 5
finally got around to getting the builtright bedside rack system together.
comes with absolutely ZERO instructions, not a big deal but assembling some of the quickgrip stuff it would be nice to have a general idea of how it is supposed to be, there website has some install guides but none for chevy
I have a bedliner installed so it has complicated things a little bit, the bottom attachment is not ideal it is a U shaped bracket but should be a u-bolt or a j bolt or at least have a L leg so you can turn it and snug it up that way, the way it is it now it just binds up so I bought some longer bolts and sleeves at the hardware and will finish it up in the morning.  I may end getting a u-bolt and drilling a couple holes in the rack I could not find one that would fit the existing holes
  • Like 6
Had my passenger side rip late last year. Easiest and quickest option IMO... replace it. Took me about an hour, worst part is getting the dang thing out! Ended up having to remove the bottom 2 strut bolts, and sway bar end link which gives you some additional room with the lower control arm dropped.
    • For a limited time, Preferred Customers and online/catalog customers get a free magnetic level with their order of $100 or more when they use code LEVEL726 at checkout. Offer ends July 28, 2026.     Save up to 25% off retail as a Preferred Customer.  Sign up here.  https://www.amsoil.com/p/preferred-customer-registration-preg/?zo=521390   As always you can order here.  https://syntheticadvantage.com
    • Looking at cheap tires for this project '95 Blazer. I'm seeing all sorts of brands I don't recognize. 235/75/15 are the size I'm after.   "Dirt cheap" (<$100/each) Starfire Solarus (AS or AT) Rocky Mountain HT2  Mohave HT Westlake SU318 H/T Laufenn G FIT Entry Level AS (yes, Entry Level is the name of the brand!)   "Somewhat cheap" (<$150/each but >$100) Kumho Solus TA51a Ironman (Les Schwab) Cooper Discoverer RT AT Hankook Kinergy ST (H735) Milestar Patagonia H/T Toyo Extensa AS II   The only one that stands out is the Cooper Discoverer in looks and actual brand recognition for me. $120/each. The buyer for this truck will probably want a visual look of not a completely smooth car/highway tire and this one has slightly blockier tread.   Starfire is supposedly a sub-brand of Cooper. Mohave is a house brand of Discount Tire. The spelling bugs me, I've always known it as Mojave. Kumho, the name, still makes me giggle.   If I was selling it tomorrow, I'd probably go with anything in the Dirt Cheap category. But I may drive this around through the fall and my mind would be ruined knowing I'm rolling around on "Laufenn" or "Entry Level" tires, name alone.   In a world where *most* tires are now offshore-produced, is one low-buck tire much better than another?
    • Most vehicles have engine covers. The cooling fan’s are below the cover. That probably doesn’t help. I cleaned collector car engines. The rest not so much since the last one protested by missing for a few days drying out.
    • Point of clarification on this graph. It is the life of the FLUID not the Transmission being graphed. Compare to his comments below the graph. Get it to the top of the graph and you can kill one in an afternoon.
