Got to look at mine also and the main bracket is all soft flexible plastic. Not even rigid hard plastic that can hold it's own shape. WTF, GM? I'll look at it more again tomorrow when I have more time. It certainly flexed a bit before the pedal moved, but it might not be as much as you guys with the stationary pedals.
I did take a second to play with the pedal adjustment and the screw for the brake does go the entire time with the gas pedal, but it has a dead spot where it stops going in just before the gas pedal bottoms out making them even more staggered. Not sure since I was quick about it but it looked like the adjustment screw on the brake is mounted in the wrong place to keep the movement going. By the time it gets to the last part it is just pulling up and not longer pulling the pedal forward.
I don't have adjustable pedals and I've always felt the gas pedal is too far back from the brake pedal which makes finding a comfortable seat distance a little difficult. I wish they were more lined up. I'm not sure if it's possible to bring the gas pedal forward some maybe? I certainly don't want to mess with the brake as I really enjoy being able to stop the vehicle!
After noticing the gas pedal has a lot of travel before it actually starts to work, I looked at it closely. I noticed it's a very bad design. There is a plastic bracket that is bolted to the floor pan/firewall and it has two studs. The metal gas pedal assembly bolts to this plastic bracket. The Bottom right area has no anchoring, and has a gap between it and the floor pan. so when you step on the gas pedal, this whole bracket flexes like crazy. I did come up with a solution. I cut a 1/2" long piece off the end of a free paint stick from home depot. Wedged it between the floor pan and the plastic bracket on the bottom right area. super glued it in place. guess what... NO MORE FLEX. Unreal how I have to do this to a $46k new 2014 truck. Never owned a vehicle with such a poor gas pedal design. Pic below.
Have you noticed any difference in throttle response?
Since the gas pedal had no linkage to keep lined up and it's mounted like it's bolted to a pillow. I'm sure you can move it and improve the quality of the mounting.
my bracket moves before the pedal moves. I'll try to make it sturdier asap. Sometimes I feel like I have to mash the pedal it to get the truck to move. How many miles do you have and do you think the pastic is starting to weaken from repeated use? Mine has 12,500 on it since June 1
Mike
Gonna investigate my pedal when I get home. I have the adjustable ones. Dunno what kind of play they have.
Hareek- That would not shim BEHIND the plastic bracket. The plastic bracket goes downward into the floor pan. you need something behind it so when you mash the pedal down it's already on solid ground. Try maybe a 1/8" or 3/16" Thick piece of aluminum stock.
My truck has a bit over 12k miles. I still think a BMW 7 series pedal would be awesome in our truck. Monster floor mounted pedal. But i'll live with my fix. If the free paint stick gets wore out, I'm using a piece of aluminum stock.
Edited by FL335i
Wow post #1 is correct.
I own a 2014 Silverado LT 4x4 double cab V-6 with a build date of June 2014 and overall I'm happy with the truck but...
I checked my truck yesterday and found this is a real problem, the accelerator pedal bracket flex on my truck looks to be ~3/4" to 1" before the electronic linkage engages. The pedal tip-in engagement has to flex the mounting bracket before the electronic acceleration switch engages.
I can't believe the GM Engineering and Design Team's would approve of such a flimsy mounting bracket for this important part of basic motor vehicle operation.
I would love to have GM explain why this is "as designed" and "normal" to have this amount of accelerator bracket flex.
I also realize this flex issue is NOT the entire acceleration lag issue that so many have complained about but this would be a chance for GM to step-up to the plate and correct a basic design flaw on our trucks.
I can't believe over time and usage this bracket will fail as currently designed.
Sure I could shim and install additional hardware to correct this safety issue, but really GM, please fix our trucks.
I would also request that someone please post a video showing the amount of flex maybe with a scale showing tip-in travel before the actual switch engagement.
I think once every 2014/2015 Silverado & Sierra owner can see the actual flex problem they will understand why we have such erratic accelerator pedal reaction from idle.
Sorry for the ranting!!!
Have a safe and happy holiday!
Edited by Rubyralph
I put two 1/2-inch shims (read: oversized lock nuts) between the pedal assembly and the bracket. That's about as thick as I'm comfortable with reusing the two stock bolts. The pedal assembly will flex a bit more, a wider, more elaborately-shaped shim matching the pedal assembly footprint is needed to eliminate the additional flex. However, the flex occurs only at and near the end of pedal travel.
The 1/2-inch shims can only do so much, the difference in pedal heights is about 3 inches originally. They're purposefully built as such to prevent stepping on the gas pedal when trying to slow down; this scenario surprisingly happens often enough. Mass-produced vehicles nowadays all have this kind of feature built-in for safety.
This thread seems to be about nit-picking, IMO. I have drove dozens of these trucks in my line of business and EVERY SINGLE ONE has had good throttle response. Maybe there are some out there with an issue but in my experience they must be far and few in between.
^kdj14- Nit picking? Really? $46k new truck and the pedal is a POS. I could go buy a 1983 Corolla and the gas pedal is more rigid. I don't play brand wars, but one pet peeve of mine with GM over the years has been the attention to detail, or lack there of. It's a gas pedal. Should mounted firmly. That's called engineering and proper building. Not fly by night junk.
Thanks for posting! I checked mine and was shocked how much it moved before the throttle actually moved!! It did help throttle response since all the play was gone! Crazy how flimsy it is!!!
Just did mine, again, wow the amount of flex, all home now with super glue and 3 washers.
Yet to drive, but feel it can only be better.
I have been having throttle response and other issues since I got my truck in late October. I stumbled across this post, and checked mine. I cannot believe GM approved this design and let this off the assembly line, the flex is insane. The actual pedal moves about a 1/2" before it even registers the gas is being pressed. I'm not nit picking as someone said earlier in this post. I wish I knew how to get a video uploaded. This is unacceptable in my book.
Has anyone had the dealer look at theirs? I'm sure its just another "that's normal" issue.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
