Update So far - with no inquiry from me, just received a personal email from the owner that they should ship out later today and will give me a tracking number soon, and thanked me for my order.
looking good so far
This is good news! Would save me some money if I order the shocks separately for the camburg kit
16 hours ago, jgraves13 said:
Anybody else see that the 6112 is available on MRT's website?
I thought the same thing... then I realized that the reason the full part number wan't listed was because they are only taking preorders now.  They mentioned in their blog on January 3 that since Bilstein released the Tahoe/Yukon versions that they expect the pickup 6112's to be available soon.  Still waiting.
Oh okay this would make sense. Interesting that they released the SUV versions before the truck versions, seems like the truck would be more popular
Yesterday, had the 5100's installed on all fours and today a new set Goodyear DuraTrac 275/60/20's.
(believe it or not I limped the SRA's to 59.6k miles...yes I was into the wear bar quite a bit..:( )
Plenty of clearance IMHO even given that it has all the factory installed mudguards
(which may eventually disappear as I sure like the looks of the truck without them.....stupid cheap paint)
I certainly noticed the truck firm up, but with 60k on the old shocks no surprise.
I must admit I miss a little of the softness of the worn out shocks but the roll is gone
and the steering wheel and front end feel so much more nimble.
I know the tires are new but are a lot more quite than I expected given the treat pattern.
(I know they will get louder, but a heavy rotation will help)
Overall happy for the cost.  Alignment tomorrow.
This purchase hopefully will keep the evil 4" BDS kit at bay.....
(for a month or two....lol)
Now on to the P&P AMP power boards
and air bags for aiding in pulling the travel trailer...
Edited by oodmoff
So I have a 2015 1500 HC with 2.5 RC kit and the 3in block in the rear ( I tow a boat ). The sway and roll is getting borderline ridiculous (i have a sloped rail road track by my house and it dam near throws my passenger out of the truck every time i hit it doing more than 5mph)  and im looking to smooth that problem out. id like to keep the "level kit" if possible and just do shocks all the way around what are my options? tires 295/55/20's AT2s
I kept my level kit on and just did the Bilstein 5100s at stock setting.  Corners and rides so much better!
what did it cost you out the door?
On 2/14/2018 at 12:48 PM, jgraves13 said:
Let us know how it works out, if everything goes well I'll order from here too as he is much cheaper than other options
Arrived in 2 days, no tax, free shipping, doesn’t get much better than that.
This happened to my 5100 Bilstein while installing. Went to tighten and shaft snapped. I was able to put broken shaft in vise and the nut came right off. I am a little worried that the quality isn't once it once was. Sent request to Distributor for replacement and was told I had to buy a new one and then send the old one back to see if they would warranty it. Don't feel real good about it.
Literally had the exact same problem a couple months ago. Who was the vendor? They took mine back no issues, and I ended up buying a replacement from a different distributor.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
