98 chevy k2500 5.7l hesitates when gas pressed
Every time it gets hot outside my truck hesitate after stopping at a stop light and has little get up and go when I press the gas petal. I have replaced fuel pump a year ago. I replaced plugs and wires 15,000 miles ago. I replaced fuel injectors to the upgraded mfi about 3 months ago.I have no idea what it could be. Any help would be great thanks!
When it gets warm out (and the engine is warm), if it is losing power in these conditions, to me anyways would indicate the fuel mixture is likely going very lean for some reason. Regardless of whether it's warm outside or not, how does the truck run before the engine comes up to full operating temp? Usually the way it works is an overly rich condition will improve as the engine comes up to temp, a lean initial mixture may seem fine until the engine gets hot, then just gets worse.
I guess it makes sense that when it's cold out the engine takes longer to warm up so it seems to run better. When it's hot out it seems almost instant that it starts to hesitate with the engine hardly warmed up. So yes it does seem to run better before it warms up and starts to hesitate once it gets warmed up. And ideas what could cause the fuel mixture to become lean?
I'm not an EFI expert, but you mention doing some upgrades to the injectors, etc. My only guess would be that there's now a fuel mapping / calibration issue. Unless the EFI system is 'self learning' which the available aftermarket ones are (and I don't think yours would be), then your computer likely needs to be tuned for your current set-up, something only a competent shop with the equipment and knowledge can do.
Did this problem occur prior to the upgrades as well or just after you did them?
because the CSFI system was such a crappy design utilizing the poppet valves that would gum up and get stuck, GM came out with the MFI retrofit unit which bolts right into place where the injector is located directly at each cyclinder intake. Both types still utilize a central "spider" with plastic tubes however.
Is the retrofit MFI supposedly plug and play or is does the computer need to be re-flashed as well?
The problems were happening before I switched the injectors, I was hoping it would fix the problem. It does run a bit better though. Some people told me to try changing the oxygen sensors and if that doesn't work then the catalytic converters. Any thoughts? Besides that I'm at a complete loss and have no idea what could cause this.
If it was doing this before, it certainly sounds like the converter(s) could be plugged. It is a 1998 truck and depending on miles and the use it's seen I could believe the lack of power is due to a bad converter and would indicate excessive back pressure in the exhaust, the condition would likely get worse as it warms up as well. I've read elsewhere if you bang on the converter with a rubber mallet and if you hear rattling, the structure inside the converter is likely collapsed rendering it junk which would plug it up good. I'd probably be eyeballing the converter as the main culprit next. You might find this useful >> http://www.aa1car.com/library/exhaust_backpressure.htm
If you take it out on the road and floor it, if it's slow to rev or just doesn't want to rev, I'd say it's pretty much guaranteed the converter is plugged.
Thanks ifixedit. I will try and look for a pressure reader for my exhaust and also I will try a rubber mallet. Hopefully I can get this issue fixed. While driving it yesterday I notices out of 5 stop lights it hesitated 3 times.
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
