Chevy overviews 2016 Silverado updates- Photo
  • Replies 79
This is a horrible redesign. Does anyone know if you can get the 14/15 style front end for the 16? To wit, is it an option to go with those front ends or is the 16 stuck on the hyper futuristic/hip look? I'd be sorely disappointed if it is.
I really like the looks of the 14/15 but like the technology in the 16 a lot. But the looks are so bad I'd rather be stuck with Stone Age technology than drive that thing.
The only time I see how my truck looks is when I am not actually using it. I don't drive the looks, I drive the technology. No matter how a vehicle looks, if you like the way it drives, and operates technology wise, the appearance will magically transform in your mind, and you will actually begin to like the appearance. Sort of like dating a person that is not really good looking, if you like the other parts, the looks begin to not matter, and you "forget" what you did not like about the person's appearance.
That's a really good point, and I agree with you completely. I was pretty cognizant of how I sounded and I didn't want to be one of those guys who only cares about the truck for looks and are like "OMG look at my new lift kit!" but on the other hand, would you drive a truck with the technology of NASA if it was hot pink? That's kind of how I felt. I feel like the new style a declension of what Chevrolet, and GM as a whole, stood for. It's pandering to the new crowd (I would say millenials but they're not known to drive trucks haha), and they're going the way of Ford, Dodge, and Toyota with the LED lighting and the really refined looks.
Anyway, in short, I agree with you but I still don't want to drive it. I love Apple CarPlay but I'll just be a reckless driver and use my phone, or I'll be responsible and get navigation. But I respect everyone's decision. I'm sure my choices make me look like a bitch to other people haha.
... I don't drive the looks, I drive the technology....
My coworkers know me for the excellent job I do.
Still, I'm not going wear work clothes at the Christmas party.
so long
j-ten-ner
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
