On 5/15/2020 at 1:00 PM, Likarok said:
Have you all looked at the new 2021 Tahoe/Suburban. They have push button shifter. Christ when I was a kid my dad had a 1956 Dodge Royal Lancer with a push button automatic. That is bizarre!
So does the mid-engined C8 Corvette.  Doesn't mean it's a good idea ....
I vote to also keep the column shifter. It's a truck and although the column shifter to some is old school, it does have practicality to it while maintaining a truck status IMO. I find the dial shifter on Ram kinda dorky and the floor shifter on Ford just takes up valuable storage space. Column shifters are out of the way and easy to reach....I wouldn't mess with it.
Dan
Dan
Amen.  Well said.  As-is, the column shifter is pretty much out of the way and is not impractical.
Dan
They aren’t doing any of these. Like mentioned above they are moving towards buttons. It wouldn’t surprise me if by the end of the T1 it was an option and standard on the new body style in a couple years.
On 5/12/2020 at 8:54 AM, Ferrari Eater said:
I feel like push button start and button shifters would be less reliable.
Today's vehicles, the key just sends a signal to the computer, same as what the 'start' button does.
Just 'bump' the key and let it do it's thing.
That said, I'm a fan of key start and column shift.
Keyless makes it easy to get out and leave one running, or drive away after dropping someone off and the fob is in possession of the other person, or...
Hard yes they should keep it. Push button start is OK with me, but no need to replace the column shifter. I wouldn't be too upset with a console lever, but thats it. Absolutely no knobs or buttons.
  • 3 months later...
Please keep the steering column shifter in the Silverado’s. It’s in a perfect position in the column, as it doesn’t take up space and convenient shifting while trailering.
Personally I prefer the look and feel of a floor shifter. Column shifters provide for more space on the console, but just look and feel so outdated.
And after experiencing push button start and the ability to unlock by simply touching a button or grabbing the exterior door handle, I don't want keys anymore.
Column and key, however if they did change the shifter i would rather it be in the center console where my right hand ends up that way i always have my hand on it.
For sure keep the keyed ignition and column shifter.  As mentioned previously i like the front center console with buckets.
Column and key for me, always and forever.  So much more usable space with gearshift on column.  Not much of a push button transmission fan for the 60s Rambler or Chryslers either.
As opposed to the push buttons I would prefer a console shift. But my preference would still be a column shift.
I am afraid though that we are getting the push buttons.
Just like my dads 56 Dodge Royal Lancer and his 65 Dodge Polara.
I think work trucks and customs will have column shift, all others will be same as the current Tahoe / Burb
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
