I am very interested in Android Auto but I don't really care to purchase an after market stereo unit, I like the stock radio. That said could I trade out a 2017 stock radio in order to get Android Auto? Is there some other component that I would need to trade out also/instead of/in addition to?
You can't just swap out the radio -- it needs to be programmed to your VIN. There are guys on this forum that can do it for you. The reputable ones are GTPrix or the guys at MVI.
Thanks for the info. Didn't realize they were tied to the VIN but it makes sense for Onstar and the wifi.
If I were to try this does the radio need to get replaced or is there a separate module that can be changed out? I thought I saw something about that somewhere in looking into this.
Interested as well.
Dealer said it would be an update when I bought the truck. They lied. :(
Interested as well.
It depends. If you have a 2014 or 2015 it is NOT an option. If you have a 2016 or 2017 it is a FREE update that the dealer can do for you.
The OP asked about a 2015 so it can't be done by the dealer (takes aftermarket updates).
Edited by sk
Except for those that got a mid year 2016 that had the 2015 head unit and the $200 credit, when units supporting AA were not available.
Mine is also a 2015.
Dealer told me it would be a simple software update when I bought my truck. They lied to me.
They lied about more than a few things but that one to me was a big one as it's something I really wanted.
The aftermarket has jumped all over this infotainment system! And that's great.
What's not great is they want more for the same upgrade than GM did when the truck was new!!!!!!!
Example: Nav was a $495 option. But could be had from most dealers for $300 if you haggled with them.
Most aftermarket options start at $650 and go to over $1,000!!!!!!!!!! That's down right stupid.
The aftermarket should beat the OEMs prices not double them!
so is android auto supposed to be on the 2017 radios? im trying to figure out how to get it to work with my android phone. i have android auto downloaded to the phone, but dont see it anywhere on the radio itself. when i go to system update, it says i have the latest update available.
Yes, if you have a Projection icon, just plug the phone in via USB. The icon will change to Android Auto.
Thanks, yea, i figured that out about 45 minutes after posting that.
So what would be the cheapest option to add phone mirroring? I don't care if it is android auto or just mirrors my phone. I just think its ridiculous to spend $600 on a dang module.
Curious to know as well.
  • 7 months later...
  • 2 years later...
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
