Installed AMP steps on the truck. I get to keep my ground clearance and the fiancee doesn't have to jump into and out of the truck anymore
I swapped the chrome mirror caps on my LTZ for a painted set.
Edited by mjonesjr84
Are these OEM, or did you get them somewhere else? Really hard to find these in Satin Steel.
They are the OEM ones. My dealer ordered them and had them the next day.
Off topic. Do you have a problem slipping when your garage floor is wet?
Every single time my shoes are the slightest wet I about bust my ass.
  • Haha 2
I installed a set of LED turn signal and marker lights on my 2022 Custom LTD. I plan on adding LED headlights as well, and then installing a DRL relocation kit, so the low beams won't be on during the day as the DRL. Instead the marker lights will be the new DRL. I'll post videos for those when I get around to them.
I used Lasfit LED's. I have a good relationship with Lasfit and have done lots of videos with them before. They make a great product for a decent price.
Swapped the Ranchos for Fox 2.0 front and back. Front set to lift 2 inches, 1 1/2 inch block added to the rear. I’m now at 40 inches on all fenders plus the ride is much more to my liking. Now to adjust the headlights.
Looks good!
Cognito UCAs with Elka 2.5 DC reservoirs 1" front and rear to level the truck- What a difference! I haven't had an opportunity to take it off road yet, but the difference on the road is substantial. I drive my truck a lot, 50k miles a year. It's a 2021 Sierra AT4 3.0 duramax and has 70k. With 70k miles my suspension was really bad, the truck bounced around specially when hitting rough road going around freeway on ramps. I hit these same spots now and the truck feels very stable. I'm still running stock wheels with 1" hub centric spacers to clear the UCA's. My off road driving consist mostly of forest service, fire roads and light desert use. I think set up is going to serve my needs perfectly.
On 4/1/2021 at 6:58 PM, lapoolboy said:
New wheels and tires
This looks awesome, and it's what I want to do to mine. What did you do to the suspension to get these to fit?  I have a leveled HC with stock 22s. Everywhere I look online says this size won't fit with my setup?
Thanks,
Installed the Gen5DIY DRL Relocation harness on my 2022 Custom LTD. This relocates the DRL from the low beam, to the side marker/turn signal lights. Helps to make aftermarket LED low beams last longer, since now they aren't running all day long when driving around. Auto headlight function remains the same.
Install was kind of a pain, but I think it was worth it.
Good mod the the Custom! If that's your truck, you've got some serious rod kill on you bumper 😁!
