Finally!!!... after almost 3 weeks of waiting for the baja design ditch lights that I ordered from GM using my points from my truck and my wife's trailblazer, they finally got delivered! They were delayed after delayed after delayed. Anyways got the brackets and lights installed and just need to do the wiring harness on Wednesday.. not going to have time tomorrow. I think they look great but can't wait to see them lit!
Added bonus to the delays were that they gave me a nice camo Chevy wind breaker and Chevy all weather floor liners for the front and rear for free!
I made a trip to the other side of the state to get a lightbar from a friend for a refurb project.  While going through a tiny town I was pulled over by a city cop for going 11 over.  😂
When he came up to the truck he obviously wanted to know why I had this in my truck.  I told him "to please not tell the (next town over police department) I took it off their car".
He wasn't amused until I identified myself.  We then talked for about 20 minutes about lights he'd been restoring.
Ya had to be there.
The wire harness is the easy part. After the learning curve via emails with Baja Designs I have come to know more than most people should regarding GM and Baja Designs products. If you decide to install the GM Upfitter switches, and choose to connect the lights to them, I'll help you figure out how much of the wire harness you need to throw in the trash. I can't believe GM decided to use a key fob remote as the only switch for the lights. Baja Designs didn't do that. It was all GM.
12 hours ago, SilverMak said:
Yeah, it looks great. What’s your set up. Tires, lift or level, etc. Sorry if you’ve already posted this information.
Happy to share!
4" BDS Lift
BFGoodrich All Terrain T/A KO2 285/65/R20
OEM AT4 Wheels
Chassis Unlimited Octane Front Winch Bumper
Yes! I am interested haha please let me know whatever you know. It would be greatly appreciated.. also I didn't see the key fob for it in the box.. what did your wiring harness come with in the box? Mine had no instructions and just the one bag with wiring harness
Also, I haven't seen the GM upfitter switches
There are a couple threads on this forum about the Upfitter switches, including a really good install write up. I'm not going into detail about them in this thread so we can stay on topic. They will allow you to simplify wiring up accessory lights and other things by not having to run wires to the battery because the switches are already connected to the battery.
As for the Baja Designs lights, GM says there's another required wiring harness you need to purchase in order to get the lights to function. That's applicable to both the lightbar for the top of the sport bar, and the a-pillar lights. This additional wire harness is where you'll find a relay, eyelet connectors for the battery, the key fob remote, and the receiver for the signal from the key fob remote. This wire harness is not needed for the a-pillar lights when using the upfitter switches, and only part of it is needed if you get the lightbar but you can get that part from Baja Designs directly, thereby avoiding wasted money and having unused parts.
I've attached a pic of the upfitter switches that I installed in my truck. To avoid derailing this thread, feel free to send me a PM if you want more info. Switch 1 is my lightbar. Switch 2 will be my a-pillar lights once they finally arrive. I've been told they're special order out of Michigan and will take about 7-10 days to arrive.
Ya had to be there.
Ah yes the Streethawk I believe. I remember having to get out of the car to smack those with my hand to get them moving again when the rotators would freeze up in cold weather. The kids are spoiled with the leds.
11 hours ago, Unwrntd said:
Happy to share!
4" BDS Lift
OEM AT4 Wheels
I love that stance. Chevy guy here but that’s easily the best looking GMC I’ve seen by my tastes. How’s your ride with the KO2s and lift?
Guarantee it’s flawless! I have the 6” BDS on KO2’s and it rides better than stock 40K in. Even in the snow! [emoji38]
7 hours ago, slumpychuck said:
Guarantee it’s flawless! I have the 6” BDS on KO2’s and it rides better than stock 40K in. Even in the snow! emoji38.png
I love this look. Are you running spacers for that stance? I have a Silverado but I’m running 35x12.5s on stock 20s and I don’t get that wide of a stance. Considering spacers
Added a swing case for some additional storage. Install was super easy. Easy to remove if I need take it out and also has two locks (one preventing it being removed and one for the actual compartment)
Looks like you had to drill some holes in the bedside for the bracket?
Edited by Steve-2019
Yeah 7 holes. Four for the mount and three for brace that holds the other end
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
