Code P0305 Cylinder #5
Ger8mm
I have a 2015 GMC Sierra 1500 All-Terrain, BlackBear Tuned, V4 Delete, run Mid-grade fuel.
This is the second time its happened within a few months, different cylinder but the same side the dealer repaired. I should still be under warranty for this fix too but can anyone else relate to this issue? Is it the tune? could the V4 disabled make the problem worse? I guess when my warranty is up and it fails again I heard there is an AFM delete you can install that should fix this issue.
I had that code pop up om my 2014. it was a loose spark plug wire on the coil end. Touched it and it fell off. Reconnected it till it clicked in place and all was good.
Cylinder 5 is not AFM.  Cylinders 1, 4, 6 and 7 are the AFM cylinders.  2, 3, 5 and 8 are non AFM cylinders, and do not have AFM hardware, just regular lifters.  Delete/Range won't help a cylinder 5 miss.
Seen plenty of bad DI fuel injectors on these 2014+up trucks that cause come and go misfires.  Loose plug wires is another common deal.
ThanksI did not know this, I will find out tomorrow but there is a loud clicking noise when it's running.
newdude, I definitely owe you a Beer now, The spark plug wire was loose.
Thanks a ton for the info and not a trip to the dealer.
  • 1 year later...
Hey guys, I have a 2014 Silverado 1500 LT double cab and at about 90,000 miles I got the first p0305 code, I have replaced the coils the wires and the plugs.  Now at about a 115,000 miles the engine light flashed as I was coming home and went off while while driving.  I checked after I got home and it was the same code, the p0305. I am crossing fingers and hoping that the injector on cylinder 5 is the only issue. I have ordered all new injectors for all 8 cylinders of course I had to buy aftermarket because OEM is too expensive. I wanted to put this on record just show another buyer of GM having issues with this. It may take another 20000 miles or more before I figure out if something else is going wrong or if the injector fixed the issue. So it may take awhile for me to reply back and if this fix the issue or not.  I'm also replacing the plugs just to be safe as well.  If this happens again, my only option is to take it into the dealership or my local mechanic if you'd turns into a rocker or when a electronic pcm programming issue.  I just hope my cats aren't screwed up.  Those are new as well as of about 96k cause I believe this p0305 issue burned one side out, so I had both replaced at that time as well.
Ok guys just a quick update, I called my shop guys about the issue, they stated for 75 bucks, they would do injector tested, cylinder compression test AND a few other things,. If nothing is found, they would swap cyl 5 injector with another non AFM cylinder and then I'll run it for a while and see if the code shows back up and is so if it's the new swapped cylinder or same old cylinder.  I guess from there well see, I'll report back if the shop find anything and what was done.  I'm crossing fingers that's it's just an injector issue, I really don't want to have to deal with an engine replacement as that will be out of my pocket. Hehehe.
You sure they will swap an injector? You need to remove the intake manifold to get to the injectors, at that point might as well just install a new one vs swapping it.
If you have some DIY knowledge you can swap spark plugs/coils/wires around yourself and even a compression test isn't hard with a kit but for 75 bucks, it may not be worth the hassle.
Report back.
Hey Ozer, they STATED they were going to do that, but after they ran a compression test and indicated the compression was VERY good on all 8 cylinders, i had a discussion with the tech.  Because the fact that compression is good and wires, plugs and coils are 'good'.  The sporadic issue comes with a few various possibilities.. the easiest being the injector is bad.  The other not easy part is there is possibly valve leak or something more internal with the engine as this is so sporadic in nature and the fact that i'm still paying on this AND may have a pretty expensive repair coming for anything internal engine related, prompted me to trade in the truck and upgrade to a 2020 Silverado LT Double Cab..   I know!! I know!!  possibly back to the same issue.  I'm crossing fingers that this one will last.  The engine a L84 5.3 which my current is a L83 5.3.  I just hope they worked out all the bugs on this one being 6 years later.  So I won't know what the fix will be as I have new truck (well it is a 'retired loaner' from the dealership with 3110 miles already).  This was the only way I could a new truck with same payments. I just rolled over the equity from my current truck as it was going to be pay off this year.  So i'm sorry guys if I caused any grief.  But I just wanted out something that could turn potentially costly in the very near future.  By the way, the new truck has a 100k bumper to bumper for only like 10 bucks extra a month.  So I feel pretty good about that part.  Good luck on all your other endeavors.
You definitely got a good deal sounds like, so no worries for many many years.
Sporadic sticking valve could have been fixed perhaps with valve cleaning DIY but not a guarantee.
Enjoy the new truck!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
