19 hours ago, gt tangerine said:
My 2021 during our first real snow of the season here in NE Ohio. I Love the truck immensely compared to my 2019 T1. The ten speed rocks.
Jealous! I wish we could get some snow. Can't say much about the 10spd since I don't have much to complain about it in my 8spd. All this talking makes me want to try the 10spd. Too bad GM does not offer it in the LTs
Had it for a week now. 2021 SLT Z31, Satin Steel Metallic
Edited by 21GMC
After the Eibach lift I wanted a more aggressive tread as well as a taller sidewall so I ditched the stock 20" wheels and put a new set of GMC AT4 18" wheels with Duratracs on the Silverado.
Actually, they do. You need the 3.0 Duramax though.
Great looking setup. So glad to see someone that don't use a set of ugly black wheels. I almost have the twin in the RST version
What size tire?
Very clean aggressive look... can you give more info on the Eibach lift , specs , size , price ... I have a 2020 trail boss and just want a usable suspension not just a “jack up” truck .. I’ve been there and want a lower center of gravity with real offroad capability.
The Eibach lift is a 2" lift that included front shocks, new front springs, and rear shocks that put me at approximate trail boss height. With the 2 " rear blocks I have right at .5" rake.  The on road characteristics are night and day better with significantly less roll, pitch, and pontooning effect.  Off road characteristics are good with less rocking and rolling around, but a tad too stiff for my liking.  If I had to guess I would say this is a suspension designed for significant on road handling improvement versus off road improvement.
Price was less than $600.  I would definitely purchase again.
11 hours ago, reds10406 said:
AT4 wheels from OE wheels in black instead of the gray. 1" level.
AT4 wheels look great.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
