Hello this is my first post here. I bought this 2020 Silverado Double Cab LT Z71 5.3 8 speed in Red Hot on 11-2-2020. My last truck was an 1981 Chevrolet K10 that I drove for 12 years.
Here is my old k10
  • Like 4
Congrats on the new ride, it's about time! LOL What did you do with the K10?
Here is my old k10
I love those old body styles
Edited by jaslon
Didn't insert text
2021 Chevrolet Silverado LTZ, 6.2L, 10-Speed, LTZ Premium Package, Technology Package, Max Trailering. Ordered the wheel-to-wheel steps, Chevytec spray-on bedliner, and Chevy Front and rear all-weather floor liners. Currently waiting on the hard folding tonneau from Rev (GM Accessories).
Replaced antenna with a stubby, and the front turn signals, reverse lights and license plate lights with LED. Tinted front to match rear. I'm in love with this truck.
Edited by Unique_NY
  • Like 4
Hello all, this is my first post here. This is my 2020 6.2 RST with the Rocky Ridge conversion, just picked it up 2 weeks ago. I traded a 2015 LTZ Rocky Ridge that also had the 6.2 engine. This one has 22's vs. 20's on the other truck. I took this pic at the hunting camp last week, I'll post more after I wash it tomorrow.
Awesome looking grille too.
Bone stock 2020 RST Z71 Crew Cab 5.3l 4x4.
Coming from a 2016 Double Cab I’m really liking the bigger cab. 0e8010e5d7fcafa92567585fab8864a8.jpg
Wow, that Rocky Ridge does look better than stock!
gave it a deep clean head to toe and some ceramic coating refresh (Cure)   Adams Tire + Rubber cleaner is my new friend, no more shine - clean works for me.
1 hour ago, Ryguy said:
First rain of the season = pics!
that wheel tire combo looks great
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
