19 hours ago, gt tangerine said:
My 2021 during our first real snow of the season here in NE Ohio. I Love the truck immensely compared to my 2019 T1. The ten speed rocks.
Jealous! I wish we could get some snow. Can't say much about the 10spd since I don't have much to complain about it in my 8spd. All this talking makes me want to try the 10spd. Too bad GM does not offer it in the LTs
Had it for a week now. 2021 SLT Z31, Satin Steel Metallic
Edited by 21GMC
After the Eibach lift I wanted a more aggressive tread as well as a taller sidewall so I ditched the stock 20" wheels and put a new set of GMC AT4 18" wheels with Duratracs on the Silverado.
  • Like 3
Actually, they do. You need the 3.0 Duramax though.
Great looking setup. So glad to see someone that don't use a set of ugly black wheels. I almost have the twin in the RST version
What size tire?
Very clean aggressive look... can you give more info on the Eibach lift , specs , size , price ... I have a 2020 trail boss and just want a usable suspension not just a “jack up” truck .. I’ve been there and want a lower center of gravity with real offroad capability.
The Eibach lift is a 2" lift that included front shocks, new front springs, and rear shocks that put me at approximate trail boss height. With the 2 " rear blocks I have right at .5" rake.  The on road characteristics are night and day better with significantly less roll, pitch, and pontooning effect.  Off road characteristics are good with less rocking and rolling around, but a tad too stiff for my liking.  If I had to guess I would say this is a suspension designed for significant on road handling improvement versus off road improvement.
Price was less than $600.  I would definitely purchase again.
11 hours ago, reds10406 said:
AT4 wheels from OE wheels in black instead of the gray. 1" level.
AT4 wheels look great.
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
