Changing from the original High Country 22" wheels to 18" factory takeoffs was a huge improvement in the handling of this truck.   I saved 18.5 lbs per corner.  Running 32 PSI now that I have a sidewall to work with.  The Bilstein rear shocks are on order.  I came from a 2019 ZR2.
Note that I define good handling in a truck as it tracks just fine wile cornering when hitting bumps, potholes a large dips.  The rear suspension should never move side to side or shudder when hitting impacts like pot holes. This is the highspeed damping in the shock designer world. Wheel weight has a huge affect in this.  The more weight that has to get over the pot hole edge must be all controlled by the shock. The rear axle weight hurts these trucks.  The entire chassis should never give a floaty feed when hitting large dips at higher speeds.  This is defined as low speed damping to the shock engineers.  The ZR2 was simply amazing with all of this stuff.  $4000 shocks sure help.
Edited by Andy Whittle
Just picked up my 21 SLT premium plus with 22" wheels. 483039991fc49bd36386006cae428e8c.jpg
Sent from my Pixel 3a XL using Tapatalk
  • Like 4
Congratulations, that is a great looking truck!
Night shot of my 2020 5.3 RST with a few mods
Edited by John Devine
  • Like 3
On 12/4/2020 at 9:51 AM, econometrics said:
Sharp! I like the added graphics and the AMP steps. ??
I swapped out my trail boss decal for these black ones .... exactly the same size and detailed as the oem factory ones just without the red color.
Edited by Jp sierra
Did some light offroading found a couple of 30 degree inclines according to the gauge on my truck did ok tires are garbage in the mud though but that is to be expected. Also got the windows tinted and my cb in my truck.
Me and my old mans 18 Jeep JK Rubicon Recon with a 3.5" lift 37's really trick jeep and a proper 2 door to boot.
On 12/9/2020 at 9:02 AM, Tjeli said:
Installed my Amp Powersteps yesterday.
I have a Trailboss (not as fancy)... and these truck options are awesome from the  factory 4x4’s  ... great looking AT4...
Which model amp did you get? I’m looking at putting the XL on my AT4. Wonder if the difference in price is worth it. Was it very difficult to remove factory steps and install these?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
