1 minute ago, Leevon said:
I don't know if I would call it cool, maybe slightly annoying and somewhat unnecessary...but yesterday I was parked on a slight incline, unloading my truck and left it running.  After a couple of minutes I hear that unmistakable whine of the parking brake engaging itself, went to check and sure enough the nanny computers decided I was in danger and applied the parking brake by itself.
I personally like that it does this for you.  Not a bad safety feature.
5 minutes ago, Leevon said:
I don't know if I would call it cool, maybe slightly annoying and somewhat unnecessary...but yesterday I was parked on a slight incline, unloading my truck while it was running, driver's door open.  After a couple of minutes I hear that unmistakable electric whine of the parking brake engaging itself, so I went to check and sure enough the nanny computers decided I was in danger and applied the parking brake.
The cool part is it will automatically disengage when you try to drive the truck.
True, and I can't really think of any major downside at this point but I'm sure I will find it if I own the truck long enough LOL
The only downside I can think of with this new electronic parking brake is the thing engaging on its own when I'm going 65mph down the highway. ?
I know (at least I *think* I know) there are some system safety overrides to keep this from happening, but it's still a freaky thought.
It's not far fetched there are accounts of the parking brake engaging while driving, it's a thing already unfortunately.  You would think when engineering made the decision to role out electronic brake master cylinders and electronic actuated parking brakes they would have been 100% ready for prime time.
Edited by Leevon
On 3/30/2019 at 2:53 PM, ShamrockShooter said:
We need to get someone working on a wiring diagram to be able to turn on the mirror task lights when the vehicle is driving. If I am driving through the woods at camp during the night, those mirror lights would be real handy
I agree!
59 minutes ago, 19gmcsierraat4 said:
I agree!
Same here! Those lights could be very useful in many situations while driving or even when locking and unlocking your doors. You shouldn’t have to push the button to get them to come on
The electronic brake periodically exercises itself for a reason likely to prevent a mechanism freeze from disuse......i.e. for those who frequently use Park without also setting the parking brake....theory being use it or lose it. Same algorithm that runs it should also prevent it from activating while truck is moving.
Mirror lights for the woods?......here's what I used when camping and no wiring diagram is necessary......lights hooked onto a 12v transformer plugged into the 110v bed outlet .......operate when parked in Acc. or while driving, conveniently controlled by an existing lighted dash switch.  Next Summer gets replaced with a 40" light bar powered by a 240 watt plug in transformer.
DSCN0765.JPG.2b8ef87cca17742779da76ca830149be.JPGDSCN0767.JPG.710cca1c6a84b02781948a7862ab3a7c.JPG
We all know the buttons behind the left hand side of the steering wheel scroll through the presets. What I didn’t realize was that when you hold them down, it acts as a “seek” feature and goes to the next station in numerical order, instead of your next preset! Mind blown. My 16 probably did it too, just never tried it, and the manual doesn’t even advertise it. Only took 4 years to find out.
If I recall, I think there is a setting somewhere where you can flip that behavior so the single press is the next station in order.
Agreed! I also wish there was a way to get the upper cargo lights to come on when unlocking the vehicle with the little hitch light. Even if the task lights turned off when you hit 30 mph would be better than when not working in anything other than park...
While playing in the vehicle customization settings I found one to automatically tilt the side mirrors down when you put the truck in reverse (SLT Sierra).  I didn't see this feature anywhere on the options list when I bought it.  I'm not sure why it's not turned on my default but it's great!!
Boost auto parts has a mod for the spots.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
