Mine is US built as well, I'm curious now if mine is going to leak. .   I wonder if one supplier was covering both the US and Mexico trucks?  I thought I heard somewhere it was caused by not enough sealant when they were installed but I could be wrong.  I've seen rear windows removed before and it was always just a rubber gasket.
The dealer told me that they had to put a new rear window assembly in because the old one had tiny cracks.  Others have said that was the case with them as well.  I know that the dealership first tried to reseal my window and that didn't work.
My truck is US built.
First attempt at fixing it my dealer removed and re-set the window. I also called GM customer service and got a case number. Still leaked.
Second attempt, my dealer removed the spoiler piece that overhangs the window and re-sealed it. Was told GM would not sign off on a replacement window. Also called GM customer service and had someone assigned to my case. Still leaked.
I sent an e-mail to GM's North American VP explaining my situation. The following day I had a phone call from GM Executive customer service rep. Long story short, my window was finally replaced. The dealer said that they found a hairline crack in my old window.
I just got it back on Saturday. I hope it's finally water tight. Hasn't rained yet though.
Still love the truck but it's been a very frustrating two months that is hopefully behind me.
From February 1st:
Quote
#18-NA-383: Water Found in Rear Interior of Cab, Water Leak at Rear Sliding Window - (Feb 1, 2019)
WINDOW RR-FULL WIDTH, SLIDING, POWER (A48)
Customer may comment on finding water in the rear interior of the cab.
The cause of the condition may be cracking in the rear sliding window plastic upper rail glass guide. The plastic upper rail glass guide may develop small fractures/cracking which allows water to pass through on the glass side of the urethane that attaches to the vehicle body.
Note: The cracks can be in the left and/or right side of the rear sliding window plastic upper rail glass guide which is covered by the roof rear spoiler. Examples of a left (1), then right side (2) visual crack (with the spoiler removed) are shown in the graphics above.
R & R the roof rear spoiler and apply seam sealer to the rear sliding window top encapsulate, following the steps in the Service Procedure below.
Important: When verifying this condition, ensure that the water leak path is due to cracks in the rear sliding window plastic upper rail glass guide, and NOT a leak in the primary urethane seal, between the window and the body.
A leak in the primary urethane seal should be addressed by removing and resealing the window, using the standard service procedure from SI.
That's nice now people have something to print ajd take to the dealer with them. I'm only dealing with the knock sensors and typical lower door and wheel well rust in my 04 Tahoe so far. This all started after 100k miles so I'm still getting along good. No water leaks though. [emoji23][emoji23]
I may have missed it when reading through all posts, but have any solid rear windows been found to leak? my 2014 had the power sliding rear and would have a few drops make their way in center of the sliding section during high pressure washes, but less than 10% of the time. not bad enough to think twice about. I now have a 19 trail boss with the solid rear window and curious if anyone with the same window has found any leaks. Ive had the truck for 2 weeks now and its been far too cold here in ND for any liquid form of h2o ha.
Mine started to leak right after it shattered for some odd reason. Wife and I were heading to dinner, when the rear passenger side glass shattered. No clue why.7b0d9040c9475766649a44448bbe0776.jpgbd43220a257dee7eed69c5fabc26e491.jpgb0181110b67af5f1c14b7b6a40f35408.jpg
Sent from my SM-G973U using Tapatalk
Damn, that sucks. It does happen a lot more than you’d think though. I didn’t know anything about this phenomenon until it happened to my dad’s Cadillac.
 Sometimes a latent defect or chip in the glass from installation will just “go off”. In this case though, I would bet that a poorly fitting frame probably over-stressed the glass in some way. Given the amount of back window issues these trucks have had, hopefully GM will take care of it for you.
Did you read through the thread on exploding rear windows? Sounds the same. https://www.gm-trucks.com/forums/topic/209824-2017-sierra-denali-rear-window-exploded/
On 1/28/2019 at 1:26 PM, GMC-AT said:
You can always go buy a Ford or Dodge since they are perfect and have zero issues... oh wait every 2019 RAM is being recalled now. https://www.detroitnews.com/story/business/autos/chrysler/2019/01/25/ram-1500-power-steering-recall/38955769/
Haha yeah the new Ram 1500's have had great quality control so far:
https://5thgenrams.com/community/threads/water-leaking-in-cab.4877/
"I had a leak in my rear window. took 5 weeks to get a new window replaced. Factory window was missing approx. 8 inches of sealant."
"What's the build date of your truck? I've seen the same issue in reading a few threads, nearly identical 'missing x inches of sealant around the rear window'."
https://5thgenrams.com/community/threads/how-prevalent-are-these-problems.1804/#post-25811
"My leak issues are in the rear and front and involve volumes of of water that totally saturate large areas of carpet. It kinda like buying a flood damaged vehicle. I am embarrassed to show anyone my $60k truck. Its a great truck otherwise but there is no excuse for these issues.....maybe rushed to market TOO soon.
I sent FCA my first "Lemon Law" certified letter today requesting satisfaction within 30 days or by-back. "
I have the 2019 Silverado Trail Boss edition. It is currently in the shop for this repair, it leaked to the point that i ran down the back of the seat, entered the seat back compartment, over filled and ran out in the seat. Almost to water bottles full. I asked the dealer to replace the carpet and rear seat, but they refused on the seat and said the carpet could be replaced, but they would have to pull all the seats and consoles out and he didn't recommend that because panels could get scratched in the process. The way I look at it if there certified people scratch a panel, then they will have to replace it. He said they did the bulletin and applied the sealer because there were no visual cracks, but I think this should be a recall. I told him that I wanted everything documented so that if a mold issue pops up they will have to replace the interior completely. I just can't believe for the amount of money (myself)people are paying for these vehicles that we can't get better quality stuff, or the backing to take care of the issues when they arise. I have been a chevy/GMC supporter for a long time, but it just seems like I end up with issues buying new vehicles that should be flawless.
  • Confused 1
I wonder if these are coming from a certain location as far as where they are built, or a certain build date?
I sprayed mine a bit in the car wash today, didn't seem to leak. Build date of 01/21/19 plant G Silao Mexico :sigh:  I'm going to keep an eye on it first time it rains..
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
