Mine's a leaker now, too.  2020 ltz built 8/19 in Ft. Wayne.  Took delivery on 1/11, 2000 miles ago.
Glass is a Fuyao E4, M1235, 43R 000072.
I caught it early, no headliner damage or rust.  I'm gonna try the permatex fix, maybe buy some time until GM actually fixes the issue.  Love the truck, wish it could be driven in the rain.  ?
I would bring it in to at least have a record of them seeing it leaking, you start messing around with this stuff yourself your going to most likely own it if you know what i mean.
So after getting my window goop with Kent sealant, it’s leaking again.  But this time it only leaks after a long rain.  Survives a touch-less car wash however.   Wondering if anyone has a copy of the official instructions to lower the headliner?
I’d like to see maybe if I can spot the breach point add some more sealant.  I’d rather delay having to go back to the dealer until GM comes up with a more permanent fix.
mine not leaking after it got replaced, but a co worker with a 19 LT was telling me that he had some smoking/burning smell and noticed it was coming from the rear defroster electrical, and that's when he realized his was leaking also
My thought is almost every leak can be fixed with the Kent sealant (other than a cracked window frame) but it’s the incompetence of the techs that is leading to them leaking after this. If a proper bead was placed on the top seam of the window and then leveled out with a finger or dowel or something to make sure it spreads evenly and goes into any void it would probably work. The sloppy job by the techs with it just arbitrarily gooped along the window isn’t doing us any favors.
Like previously stated, I fixed mine myself with the permatex window and glass sealant which is a lot more viscous and goes into every nook and cranny - this is after I had the Kent sealant done by the dealer the first time.
Does anyone know if you have to drop the entire headliner, or can you just lower the back side to remove the roof spoiler and seal the rear window?  The GM TSB pics seem to show just lowering the back of the headliner. But it wants to hang up on rear window slide channel and I don’t want to crease the headliner.
Dealer said they couldn’t just drop the back of my headliner, wasn’t enough room to work without creasing it. So they took the whole thing down. Take that for what it is.
These are awesome, thanks Brandon. Do you happen to have any of these on the sunroof? After mine was repaired, assuming they dropped the rear of the headliner, the sunroof shade is scraping in the dome light area. Would love to see a diagram to see if it’s off the track. I have a borescope I am going to drop the dome light and see what’s going on in there.
While everyone is self quarantining they should watch “American Factory” on Netflix. It’s about fuyao glass company.
Quote
Just picked up my ordered 2020 LTZ crew cab.
Going to add a camper cap.
The question is to all those who have endured this leaking problem.
Would you add the flowable sealant to a new truck without a leak as added insurance for future problems?
Really don't want to have to pull the cap back off for a repair and with the cap installed you probably won"t see any extra sealant anyway.
After 125 pages, I am just trying to be proactive for a potential problem that truly seems be "Rocket Science " for GM engineers to solve.
Thanks
Mike
Thanks
Mike
I honestly wouldn’t touch it until it actually started leaking. There are a lot of leakers out there but it’s a small sample size of the hundreds of thousands of trucks out there. Who knows, you might get lucky and get a dry one!
hotrodz37
Thanks for your fast reply.
Guess I will let it roll as is and lean on my Irish heritage a bit.
Hopefully this is my last post on this subject. LOL
Good Luck to all.
Thanks
Mike
FYI if your truck has the camera in the rear brake light it won't work with the truck cap.
Sent from my Pixel 4 using Tapatalk
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
