Add me to the list of leaks, I have a 2020 GMC Sierra AT4. I am in the waiting area at our local dealership now. They will be attempting to remove the spoiler / headliner  and squirt the clear seam sealer in between. Fingers crossed. I am not happy about the seam sealer but i would would be more frustrated having the back glass cut out. Will update in a week or so.
As Pink Floyd sang,   WELCOME TO THE MACHINE  :( , While i love the song, i hate the process.
"By the way, which one's Pink?" Great song.
edit - Not enough coffee this morning. The quotation is from "Have a cigar"
As for the original topic, so far no leaks with my rig.
Edited by SVG
Brain cramp
Absolutely horrendous, so many thousands of units with this issue.  Is your truck the Slider Window or Fixed Window?
My truck has the slider. They told me the seam sealer has to dry 24 hours before I can get it wet, but my truck is ready for pick up. It only took them two hours for the “repairs”. I asked them if it still leaks and they said they cannot water test it for 24 hours. So then I asked them how is my truck ready for pick up if you do not know that your tube of seam sealer fixed my leak. Idiots.
  • Sad 1
I got my truck back and so far it has been through two torrential downpours with no leaks.  From what I can see they did a decent job of applying the sealant.  I had no paint scratches or scratches on the interior trim, so I'm pretty happy about that.  The only issue is now I can occasionally hear a "pop" noise from the back of the cab while driving.  I assume it's the spoiler, because it seems to be coming from outside.
Probably due to being over tightened.
Might be this.
https://gm-techlink.com/?p=14435
Add another 21 GMC Sierra 2500 with a weeping window. 2500 miles, but appear frame Is intact still. Almost looks like it’s a poor seal on the driver side where the frame is glued to Glass on the top edge and there looks to be a weak amount of sealant compared to passenger side. Going into dealer Monday, fingers crossed they are gentle with her.
Edited by Armgrim
I am having the same issue. Just bought a new GMC 2500 Denali. Had it for three days and it rained. The top plastic track that the power rear window moves in has a leak. It  looks like the track is glued or sealed to the window. Started to leak right where the track and the window meet at the corner of the track behind the driver side.
  • Sad 1
On 7/19/2021 at 11:30 AM, SilveradoRST said:
Might be this.
It's possible.  I only notice the popping noise on really warm days.  I looked at it this morning and it seems to have plenty of room, but it is only 82 degrees right now.  I'll check again this afternoon.  Thanks.
And I am now on my 4th leak as of yesterday.  Today, the lemon law attorney has been contacted.
As assumed they played a bead of seam sealer on top of window to start the process. We shall see if it keeps it sealed long term. Good news it’s on Saturday got a good rainfall and it didn’t leak in so it would seem only to leak during a car wash with water spraying up in that area. They did a good job to get the interior back to the same shape as I dropped it off so that’s a plus.
I consider myself lucky that mine only drips a small amount when its in steady rain for 6hours +. Until there's a rea; "fix" I cant see trusting a dealer to "try" and fix it...possibly making it worse.
Add my 2019 to the growing list of leaks. Took it into the dealer and they leak tested it and confirmed the leak. Adviser said that they wouldn’t do the sealer that they were just going to replace the window. Got my truck back today with a new window. Fingers crossed it’s fixed. Strange that Safe-lite is who installed the window.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
