2015 Sierra Lifters went out TWICE! Now they won’t warranty
39 minutes ago, Jonathan Ochoa said:
Thing that makes me even more mad is the fact I only owe like $3800 on this turd ! Smh !!
Yeah, maybe you can limp it along til you can get it paid off.
  • Replies 70
18 minutes ago, TXGREEK said:
Did they mention anything about your tune as being the reason for denying warranty and did you disable it prior to bringing it to service?? Questions every mod enthusiast wants to know.
Sent from above
I took the tune off before taking the truck in . That way they had no excuse
15 minutes ago, Tahoe02 said:
You have a really nice looking truck. Keep it for now and pay it off. You have 24 months of warranty to decide what you want to do. You could also consider an extended warranty if you decide to keep it. Several threads on how to get the best deal on the warranty.
I think I might go with the extended warranty on it . I owe to little to let it go and get into way farther debt !
Excellent choice, I’d recommend a slight overhaul and keep the AFM disabled. Later, get new wheels and tires and you’ll have a newer looking truck. Less is more [emoji6]
Sent from above
31 minutes ago, TXGREEK said:
Excellent choice, I’d recommend a slight overhaul and keep the AFM disabled. Later, get new wheels and tires and you’ll have a newer looking truck. Less is more emoji6.png
Sent from above
When I bought my 2018, I started driving it in L7 until I got the Range. I literally have less than 120 miles of the 3,879 on it with AFM on and even then it was not in V4 mode for that whole 120 miles...that whole system will be gone after warranty.
Ive got 85k left on my warranty, I’m thinking it’ll be gone before I reach the end of warranty if I ever have any warranty issues. It’ll be Raptor time only if GM doesn’t bring in a Raptor version of their own. I’ve never heard any issues with them at all.
Sent from above
4 hours ago, SS502 said:
Just WTH do they fall under? Not jumping on you Capt! They damn sure are a part of the powertrain.
Went back and re-read the powertrain warranty. It was "injectors" not lifters. My bad.
I wasn't questioning your post, I was getting ruffled thinking they weren't covered LOL...didn't mean to sound like I was harpin on you Capt!
GM replacement parts and labor are covered for 12/12. Don't know where they get 2 years from.
I could be wrong, I’ve heard When serviced by GM it’s 2/24.
Sent from above
Sent from above
Parts replaced under warranty are covered for 12 months unlimited miles, or the remainder of whatever warranty covered them initially whichever is longer.
If you pay for as repair most are 24 months,  unlimited miles. Some are 24/24, some are 12/unlimited, and some are 12/12.
Same goes for parts purchased over the counter but the labor isn't covered.
Yup 100% correct ! Some bs that the gm part it voided after my warranty expires
Well my initial statement of 12/12 is wrong and Hollywood seems to to be well informed but check this out directly from GM.
Also found this. So it's no wonder someone would get different answers for different dealers/employees.
Never crossed my mind.
Coming from a Duramax, I suffer from injector phobia.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
