2015 Sierra Lifters went out TWICE! Now they won’t warranty
Out is out. Nothing the dealer can do but run the calculator and see if GM wants to "participate". It is much harder for the dealer to just "Goodwill" it now days.
  • Replies 70
So the issue is the claim needs to be a continuing issue. Meaning saying they fixed it and it was good but then out of warranty it broke is a denied warranty claim. Saying it was never right dealer tried and still same issue is different. And 2/3 of the lemon law. But the lemon law is bull anyways.
I will say that price is crazy. I can do a heads cam and fuel high side for that and with those miles just buy a low miles used block for cheaper and have it in in half a day.
Ya the dealer that did the work instantly said nope we will not warranty anymore . But the dealer that has it now had my call gmc and see if they could at least help me out . But nope :/ . The senior advisor will be calling me tomorow to see what they can do . Which I’m sure nothing .
Oh I think it’s crazy too , but the hard part is it broke down almost 2 hours away from where I live and the only reputable place was the gmc dealer . The truck is already fixed . I just haven’t went and picked it up . Was hoping gmc would least help me out a little
I’m curious, if they fix it are you still going to keep it? I would have unloaded it the first time. I would have been worried the other side was going to go out.
Bad situation.
How about some data?
Oil change info would be first on the list.
Towing history.
No cylinder deactivation delete?
Bone stock?
Just curious.
Some vehicle history would be nice.
10 hours ago, Capt Bob said:
I don't believe the lifters fall under the power train warranty
Just WTH do they fall under? Not jumping on you Capt! They damn sure are a part of the powertrain.
If it were me I would have it towed from that dealership and here is why. They repaired under warranty and 20,000 miles later problems on same bank again. A good dealer would supply the labor and try to get GM to foot some parts . If GM won't he could offer parts for repair to you at a discount off list price. In realty his tech cost him probably 30 or so per hour . Lets say 30 x12 hr. for example . For 400dollars of his labor and you buying parts worst case it could still be a win win for both. Seems like dealer is throwing the baby out with the bath water and telling you tough sh.t.
I’ve seen power train warranty’s cover the engine block, not heads, transmission not converter, rear end not axles. I’ve read where an external vacuum pump goes out and send debris through the engine. The engine not covered because the pump wasn’t, which caused the failure. That’s the main reason I go bumper to bumper. And yes heavily discounted. As you know reading the fine print is a must.
13 hours ago, Jonathan Ochoa said:
So back in November of 2017 my 2014 GMC Sierra started rattling super bad . I towed to dealer ship and found out my left bank lifters have gone out . No big deal they warrantied them. For the next few months I took it back for the smell of anti freeze . They gave me the run around saying nothing is wrong with it . Fast forward to February 23rd 2019 truck does the exact same thing and I take to dealership . Bam the same exact lifters are out again ! But this time they tell me it’s no longer in warranty and that it expired in  November 2018 .. they will not cover it even though it’s the exact same problem and the same lifters as the ones they replaced !!! I called gmc and said since I’m out of warranty there is nothing they can do ! Any advice to Get them to warranty this out !!! It’s bs !!! $3200 to fix !
Mine cost $2063.34 Total under warranty.  It was a 6.2.  Parts $818.76 Labor $1244.58
Oil changed every 7K.  I drive 30K miles/year
I picked it up when ready and drove to the GMC dealer and traded it in.
Lifters.pdf
Yeah, I know some don't but his first failure WAS covered, now suddenly they are not. I know or suspect he is past warranty, but MOST times if you have a repeat failure after a warranty repair they will at least work with you. Obviously his dealer isn't and so far GM is not either. It is what it is but lifters at some point fell under the PT warranty. Extended is a crap shoot IMO and yes I have one.
Proves to me a warranty isn't worth much. Definitely not worth the cost of a new truck IMO.
1 hour ago, diyer2 said:
Bad situation.
Towing history.
Bone stock?
Just curious.
Never have towed with it
and yes I did the cylinder deactivate on it after reading up on lifters going on the first time .
I’m running a leveling kit on 33s same stock rims
oil changes done every 2500-3k miles . Full synthetic
i baby this truck !
I’ve said it time and time again, call your local media station and let them know everything that’s been going on, dealership and GM will fold rather than having bad publicity.
Sent from above
Op i hope you take my advice. Or get it fixed and trade it in. I will tell you this. Lifters don't just fail. There's something else going on like worn cam lobes, grit in the oil system or the block tolerances out of wack. If i was you I'd either fix it trade it and take a loss, do said cam swap myself or have a lawyer rip and get a new engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
