I’m at 3000 miles and I noticed that it comes from the long trim piece around the tail light on the roof that goes all the way across from door to door . I have the 2019 Chevy custom. And it happens when it’s been out in the heat and when I make sharp turns or over a bumpy road. Not so much in the morning when it’s cool l. It  only happened a little at first but has gotten worse. Almost like the plastic clips underneath the trim strip are flexing. If you push down on it. You can re-create the sound.  Mine is a double cab
Edited by Rkkiz
I thought I was crazy, but I have the same thing happening to me on my Custom Trail Boss. Sounds like a large bird poop hitting the roof lol. Definitely towards the rear like mentioned here.
Yep I get the noise occasionally and at random times (morning in the dark no sun) mid day, evening etc
Hadn't seen if anyone with a double cab had posted yet but mine does a little pop now and then too so I figured I'd mention it's not limited to the CC. Doesn't bother me though. In my wife's 2016 RAV4 we traded a few months ago, you could literally hear the whole unibody creaking and popping when going over un-even pavement or dips. It seriously sounded like every joint and weld was gonna break loose lol.
Edited by batman900
Never had that on my double cab, even on really hot days in the Sun. But when waxing the top, that roof metal is mighty thin and can easily be popped in if too much pressure is applied.....situation would be worse with the larger surface area of a crew cab. Might have something to do with the fact that many of the formerly steel panels have been replaced with aluminum.....maybe working like the biometal strip in a thermostat and dissimilar expansion rates under heat cause a creep or pop.
I've got a sunroof and I DO have the same popping.  I kept thinking an acorn or something dropping out of trees hit it, but then its happened several times with no trees around.  I can live with it, but I sure would like to know what it is.  The noise behind the back seat drives me crazy.
2019 rst cc no sunroof. Popping noise and I too have heard the noise when washing. Seems to be coming from the spoiler. Randomly hear it while driving as well.
On 5/3/2019 at 10:57 AM, DirkDiggler84 said:
Anyone getting a popping noise from their roof?  Every morning when I pull out of my garage and go over a slightly angled transition between my driveway and the street I get a popping from the roof.  I've heard it several other times when driving at low speed as well.  It sounds like the sheet metal is flexing, like if you were to slightly indent a piece of sheet metal, it slightly indents and then you push it in another spot and it pops out of that indent.  I have gotten a very similar noise from the lid on my washing machine.  I do not have a sunroof.
Yes, was figuring it just needs a break-in period.  Doesn't bother me that much...
Edited by BobbyAlton
So much for hasn't happened so far, pulled from the shade into the hot Sun and heard a pop.
I have the same sound on my 2019 trail boss LT with a sunroof. It happens about 3 times every time I drive it. Please let me know if anyone has a fix to this. The truck has 300 miles and it’s driving me crazy.
Edited by Cody2019TB
Same pop here, crew cab SLT and sunroof. I agree with the others, thinking it is just expansion from temperature changes. Going to ignore for now since I don't want my headliner removed.
Trail Boss LT with 1300 miles and have the roof popping. It's been there since day 1 and drives me crazy. Really hope they step up and find a solution for this.
I have only heard the popping sound while washing my truck not while driving. When I spray water on the roof I do sometimes hear a loud "popping" noise.
Same here...noticed the same thing the other day it the touchless car wash. Coincidentally on my way to the dealer for an unrelated item. Dealer says it’s likely roof sheet metal flexing. Going to see if it happens more frequently.
    • if you want a short turning radius get a short bed Colorado!
    • that is pretty awesome MPG there!  I think so far one observation is these trucks do way better on MPG under 65mph vs 70+ and they really suffer at 75+   I noticed on the stretches into NE on 76 and 80 which is posted 75MPH and I was doing 82 I was getting more like 13.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
