Can anyone clarify what other GM models’ mirrors are interchangeable with our trucks ? I see some in this thread have found Cadillac mirrors. There’s Escalade mirrors on eBay for $300. 17-20 model year. They look a bit different and different part numbers.
Edited by HoustonVol
Here you go. I found some camaro ones for 200 ish I just need to verify they fit2ab98192beb6a759034c55d588692fa0.jpg
Sent from my SM-G973U1 using Tapatalk
IDK if the Gen 1 mirrors work in our trucks, I know the 2019 CT6 uses the same mirror part number as our trucks.  Someone earlier in the thread used a 2019 XT4 mirror, he posted the part number.
does any one know the part number for the actual camera inside the light? I did this install with a rear view mirror cam/bed view cam lense and did not look before i put it on. i have a high mount light but it is a bed view type cam and i want to put rear view mirror cam in it to sell.
Installed mine today. Thanks for all the part numbers and install tips!
Where did you get the mirror from?
Ebay. There was a reseller that had take offs. Wasn't any cheaper than the gmparts websites but it works and I'm happy with it.
On 7/9/2020 at 3:30 PM, pewterliftedz said:
Can someone look up the coax cable for a escalade or tahoe, that one would be longer and eliminate the issue with having to order a new spoiler.
I’ve seen this one a few times. It says it fits model year 20’ Escalade and xt4. Fiat, do you think this would work ? Or is the housing with harness still the only way to go?
do you by chance know part number of the actual camera inside the high mount brake light?
I didn't see any numbers on it.
17 minutes ago, HoustonVol said:
Someone posted earlier in this thread that the camera is #84699124
https://www.gmpartsdirect.com/oem-parts/gm-high-mount-lamp-84699124
I think that is high mount light part number. heres a pic of mine. i want to verify what cam is in the light.  I had a bed view cam in my mine 84676845 also same type they use in 360 view cams in 2020 models.  i am trying to figure out if rear view mirror cam has a different part number.
On 11/18/2019 at 10:25 AM, Yoda2 said:
Hazem,
Was dropping the entire headliner a must?
Did you have to remove the seats?
I looked at an A1 You Tube video and it looked like a nightmare.
Some of you guys are a lot more courageous than I.
This is a brand new truck to me and I'm worried about damaging the headliner.
Steve
Can you post the video?
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   4 Members, 1 Anonymous, 725 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
