For those of you looking to setup your own MultiPro tailgate speaker system, well HERE YOU GO! Wiring harnesses and amplifier brackets to make your project super easy!! No splicing or hacking away at your expensive factory wiring! I have a limited number of the items in stock, 10 or so of each, with more that will be ready next week!
When I did mine, I used the Soundstream ST4.1000DB bluetooth amp (and I am very pleased with it so far), so all of the options are available as plug and play with that particular amp. Or you can just get a harness with a pigtail that will give you 12v+ power and ground in your inner tailgate, so you can wire it up to whatever you want. Don’t forget to check out the options for adding lights and the speaker wiring harness to make the whole system truly PLUG & PLAY. so much better sound than the Kicker system for a lot less money!
All items come with complete installation instructions (with pictures, ha)!
Let me know if you have any questions!
www.multiprorocks.com
Edited by Mason603a
add information
2 hours ago, Coastie said:
nice design, nice website, good job!
One thing I couldn't notice in the wiring harness, is there an on/off switch?
Thank you!!
there is not an manual switch but there is a tilt switch integrated into the harness that automatically powers the amp on (but doesn’t automatically play music) when the inner gate is fully deployed (down) and automatically powers it off when the gate is folded up. A manual switch could easily be added if someone preferred that.
let me know if you have any other questions!
10 hours ago, Kyle's AT4 said:
Do you have a picture with the step closed to show clearance?
Sent from my SM-G973U1 using Tapatalk
The step easily closes without the speaker grills, but I wanted the grills on so i stacked some fender washers in under the step and grabbed some longer screws from Lowe's.
Edit: duh you said pictures and instructions are included.
next dumb question, does the accessory power need to be on? This is my first sierra and i'm not sure if the trailer power is on when the vehicle off.
Evin
Edited by Unwrntd
12 minutes ago, Unwrntd said:
will you be doing an install write-up?
Yes, should have one done today or tomorrow!
Evin
The truck accessory/switch does not need to be on. The trailer power is always hot, hence the need for the tilt switch.
Edited by Mason603a
additional info
  • 8 months later...
I am trying a slightly different approach on this. I have a 3D printer, so I have designed replacement panels along with panels that have recesses for the bluetooth controller and an aux port.
Once I get the marine speakers in, I will print panels that have mounts for them as well.
So, any progress or pics? I’ve been trying to reach the OP about purchasing his kit, but no luck. I real want an aftermarket setup
for the tailgate.
for the tailgate.
Same here. Would love to know if anyone has more details about the harnesses to get this working.
I have mine working. I had to reprint the parts with PETG filament to make them UV and sunlight resistant. The first ones warped.
I wired in a power switch as there are times I will use the system without the tailgate down (for example when camping and I have my hitch in). I also, just ran a standard amp wiring kit along the undercarriage rather than cutting into or modifying my 7pin connection. The 10 Gauge wire was much cheaper than buying the $90 pigtail.
BT Controller - https://www.amazon.com/gp/product/B00WVTS4R4/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
4" Marine Speakers - https://www.amazon.com/gp/product/B08P7CKXBD/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
USB port - https://www.amazon.com/gp/product/B07SWZRFRS/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Wiring Harness and Wire - https://www.amazon.com/gp/product/B08FRRC4RN/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1https://www.amazon.com/gp/product/B01C7O7Z68/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Power Switch - https://www.amazon.com/gp/product/B07P68NFXZ/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
3d Printer STL Files (I printed them with PETG, and only did supports on the speaker mounts).
- Speaker mounts (these have a lip the slides under the tailgate metal, is is tightened down when you screw the speakers in https://www.tinkercad.com/things/cYdAZhWyiD6
- Blue Tooth Controller https://www.tinkercad.com/things/j6kqISHpcYt
- USB Port Panel - https://www.tinkercad.com/things/ldsRsnBkZs0
Here are the components I used
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
