I have been trying to find the 5100 series rear shocks for my AT4 and can't find them in stock anywhere.  Does anyone know where to find them?
Part # 24-309516
Thanks
Believe they are all pretty much on back order. Same with Eibach. Been waiting now two months for my set.
Had the front ones installed 2 days ago and am very happy. Like mentioned by others it just feels so much more planted than before and really makes a difference on the sharp bumps like pot holes and joint separations that like to appear around here when the frost sets in. They are a noticeable improvement from stock.
Can't wait till I can find the rears in stock somewhere and get them installed.
  • 3 weeks later...
Did you use them to lift the front at all?  I’ve had the rears for about a year. Having the fronts installed next week, trying to decide on height.
Mike,
I did raise it to the highest setting which kept the front about 1" lower than the rears. My truck was 2 1/4" higher in the rear originally which was more than I liked but didn't want it totally level because if hauling heavier weights I didn't want the rear to squat much.
Are you happy with the rear set?
Edited by wurgs
40 minutes ago, wurgs said:
Mike,
LOVE the rears. They made a huge difference by themselves. My rear is almost 2 inches higher than the front on the dot. I think I’m going to do a 1” lift in the front. I like like the look of a slight rake.
Edited by Mike Borowski
I don't have any big complaints with my truck's adaptive ride shocks/ struts, but curious if anyone's swapped them out - did the High Country's on here come with them?  How do they compare?
I’ve had the 5100 rears for about a year and it’s made a big difference. Had the front installed today and it’s like a new truck!  By far the best mod you can do for the price.
After having the fronts installed (I had them set at 1" lift), is it necessary to get an alignment?  I don't feel any symptoms of needing one.  Maybe the shop included it in the install...
Yes, literally every part of your alignable front parts will have been disturbed.
That is, if they didn't do one for you.
I’ll have to call and ask. I would feel symptoms though right?
Not always. An alignment can be out in a number of ways that isn't readily noticeable by odd handling.
My truck's alignment isn't correct anymore at 61,000 miles but it seems to drive fine.  Insides of my front tires are wearing noticeably more than the rest of the tread.  Tires are at the end of their life so I'm just waiting to get it aligned when I do the lift and new tires this summer.
  • Thanks 1
If anyone is curious this is what an RST looks like with 5100’s set to 1”. The rear is about 24” from center cap to fender and front about 23.25”.
Really happy with the 5100’s. Ride quality is much more stable, handling is tighter, no nose dive when braking, it looks better and I’m ready for bigger tires and new wheels soon.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
