On 8/4/2022 at 10:41 PM, Janko Sakuzov said:
Just did a full suspension install.
5100 on the front set to 2"
1" Motofab spacers under the 5100s for total 3" front lift.
Motofab UCAs
5160 in the back with Motofab extensions
Motofab 2" blocks on the back
Firestone Rite Ride airbags were already installed on there. Might need spacers for them
2" Bora wheel spacers all around for a little wider track.
As it sits right now there's about 3/8" -1/2" rake still but I'm ok with it. I could still raise the 5100 one more notch to bring them up another 1/2" to make it 100% level, or take out the front motofab spacers and raise the 5100 the other 1/2" to be back where I'm at right now. Probably won't touch them though.
Ride is spot on now, but the real test comes in a couple of weeks when we take the 30' camper out. Main reason for all the work was to hopefully smooth out the front bouncing on the concrete highways around here when we tow. I have the weight distribution hitch spot on to spread the load 50%-50% . The Airbags in the back helped a TON with that, but the front was a complete ****** show. On some stretches it's so bad we stopped camping on the west side of the state to avoid those highways. F073CB74-6CA6-4139-8DF1-6B1F3F0DDFAA.thumb.JPG.a7c1a62bbfc241352c1a36e134480b6d.JPGF5C6474E-E4CB-4FC5-9650-DFE7357592AC.thumb.JPG.a3bc790b41c42bec3a2ba151a2c7f975.JPG
Any updates on this setup???!
  • 3 weeks later...
On 8/10/2022 at 3:26 PM, Amcguy1970 said:
One thing I do not get is the comments on how "smooth" these shocks ride, that isn't at all what they do or are known for. They actually do the opposite on rough broken pavement with any kind of added lift from the shock. I have these, they are an improvement, especially on the large bumps, but they actually ride a little rougher on the small stuff. Just want to make sure people who read some of the rose colored glasses reviews what they are really in for. Steer clear of reviews that mention night and day, huge difference or boast how smooth the ride is. The larger you lift you add with them the stiffer they get as they pre-load the spring to attain lift.
Overall they are a fantastic upgrade if that is what you are wanting (to control the large bump pogo effect and side to movements) but if smooth ride over broken pavement is it, then that is not the case. Now if you go large with the tires and stay in a P rated size and someone goes from a 20" to an 18" wheel and they boast smooth ride, then that will be attributed to the tires, not the shocks and lift combo.
Again, very happy with mine (though the stock ranchos weren't bad by any means) but some of the reviews on these are just far out, same goes with some tires...
I will also be looking at the eibach's next time as I have heard some good things about those.
Tyler
Agree with the above. I did not like the 5100's ride over small bumps and even some larger higher speed hits. This is with the 5100's only on the rear. Did not bother mounting the fronts. Switched to rear Rancho RS9000 with damping set on #3 position. Supple ride, good comp and rebound plus I can feel the weight transfer due to better suspension response/articulation. 5100's felt numb. My Silverado is a bare bones 2020 WT DC 2WD with 265/65/18 Conti A/T's on TB Reps. Stock height. The 5100's are probably better suited for hard working lifted trucks with larger wheel packages.
Bilstein 5100's front and rear (trailboss part number)
24-309509
24-309516
Rough Country UCA for 3" lift
Motofab rear 2" block with U-bolts
+2.5" in the front
+2.0" in the rear
I know the pic shows otherwise, but I put the front strut circlips set to the middle position for .55" of lift.  Wanted to maintain a touch of forward rake, and with the extra weight of the diesel it worked out perfect.
This is the 3rd set of 5100's I have purchased (jeep life) so I knew what to expect.  No, the ride is not smoother or a night and day difference.  In fact it is a little firmer.  But there is more steering response, and way less rebounding that happens over speed bumps or highway bridge sections.  I also noticed much less side-to-side rocking that happens when I pull into the parking lot at work, which is a fairly steep diagonal transition that flexes out the suspension.  Overall, a great purchase.
My other vehicle is a 2004 WJ Grand Cherokee, and it is really nice working on a brand new truck where nothing is rusted or stuck!
342886583_IMG_4124MEDIUM.thumb.JPG.f588c6f7a9aea92c206991312027d898.JPG150917892_IMG_4116MEDIUM.thumb.JPG.a17095cbe83a7d923dbd78e628ae2c38.JPG7EF4A669-6539-4941-B704-530A3291B08B.thumb.jpeg.d21ef825dd92c5737eda99d5465ec73a.jpegFA99D60C-DB8A-49AB-8D45-C3E44D48F82B.thumb.jpeg.d45f5ed546a0021705fb5acb558480a5.jpeg
Edited by mdrum93
My 2022 LTD custom feels like a boat going down the road...I think Bilstein 5100's are in my near future. I just installed a set on my 2019 GMC Canyon and its night and day!
  • Haha 1
I have a question about the CV axles. If you use the Billsteins to lift the front 2" or 2.5" will you have problems with the CV axles? I see the GM factory 2" kit comes with new CV axles, I assume they are longer than stock axles?
Edited by Diamond817
Yes they use different axles.
Mine is “so far, so good” with 2” of lift and the stock axles. They ever fail and I’ll buy Trailboss spec CV shafts.
Ok, good. I've decided to go this route instead of with the 2" GM kit. I really didn't want to lift the rear of the truck 2", so I'm going to do a 1" rear lift and a 1.5" or 2" front lift.
1 hour ago, pnw_obrigade said:
Has anybody used the Motofab AT4 1.5" preload spacer on 5100's to get more lift than 1.1" on the 3.0 Duramax (assuming the Bilsteins are set in the stock position)?
There’s a dude earlier in the thread that did Bilstein to 2” and added a 1” bottom strut lift. I tried messaging him to see how it’s holding up, but no response.
As of now, I have mine set to 2” and I’m going to add a bottom 1.5” (Supreme Suspension) with some Rough Country UCAs and a differential drop spacer kit.
In the rear I have Rough Country air springs, and a 1” block.
Once it’s all completed I should have 3-3.5” Front and 1.5” Rear… (Bilsteins have already settled half an inch and Air Spring kit added an additional .5”)
I’ll keep y’all updated, but I don’t plan to finish it up for a few months. Between the UCAs and differential spacers I think it’s going to ride pretty well considering the shock upgrade.
I’m quite astonished when I read some of these threads about shocks and brakes on these trucks. I never changed shocks or brakes for the time I owned my trucks. My trucks usually had tool boxes and fuel tanks. I put a lot of Hwy miles on. They spent lots of time on pipelines. The only thing I can figure is they changed a lot since my last new one 2014. Or people are awful picky. I spent my money on performance upgrades.
You’re missing out
  • Thanks 1
44 minutes ago, Mike Borowski said:
You’re missing out
I always owned a mixture of vehicles. Sports cars, luxury cars performance trucks. If something was amiss I would have noticed. I’ve had Z71s and FX4s. If they’ve gotten bad since my last one, shame on GM.
LOLZ at all the peeps trolled by this thread that was probably started by a Bilstein distributor...
"My truck handles like a '72 Eldorado!"
I owned a 73, my father bought it new gave it to my grandfather. I bought it from him. I owned 13 Impala’s a few olds, Buicks and Pontiacs. In contrast my wife favors sports cars. Even two fieros, a couple Camaros, two mustangs among others. I know the difference between a good ride and bad. I put money into performance, engine that is. I can see different shocks being an upgrade. Not enough that I’ll go screaming to pull off the stock ones that are new. Now a two barrel on a V-8 or quite exhaust. When I was younger they were changed the first thing.
Speaking of trolls...
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
